Need a Wacom EMR pen
Discussion in 'Accessories' started by rirawin, Feb 8, 2018.
  1. rirawin
    rirawin Scribbler - Standard Member
    214
    18
  2. nyb72
    nyb72 Scribbler - Standard Member
    256
    166
    Which device are you using it for? Different EMR pans may produce different offsets depending on the device.
  3. rirawin
    214
    18
    Need one for the Yoga Book
  4. DRTigerlilly
    7,523
    701
    301
  5. rirawin
    214
    18
  6. DRTigerlilly
    7,523
    701
    301
    Granted, the Lenovo you asked about is the same one I posted above. Theoretically it should work, the only concern is offset, and b/c of the Yoga Books setup, calibration might be difficult.
    Going to look if there is a way to calibrate on that device.
  7. ORTOX
    ORTOX Scribbler - Standard Member
    108
    DRTigerlilly, is the nib in the Toshiba Tru Pen replaceable? Also, thanks for the tip on the $8 pen. It looks like it's still available on that site. I may just need to order a second for my Z20t.
  8. DRTigerlilly
    7,523
    701
    301
    They are replaceable, I idly bought felt nibs from Wacom they had to be filed down but they fit (there's a post around here somewhere), unfortunately Toshiba doesn't sell replacement nibs.
  9. Shizaru
    Shizaru Scribbler - Standard Member
    556
    392
    A Wacom UP-817E maybe another alternative it has two buttons and eraser. They still popup on E-bay from time to time.
  10. yoyoshuyang
    yoyoshuyang Pen Pal - Newbie
    Shizaru likes this.
