Need a tablet for study
Discussion in 'What Tablet PC Should I Buy?' started by ultra99, Apr 3, 2020.
  1. ultra99
    ultra99 Scribbler - Standard Member
    154
    I've used several tablets in the past, MS Surface Pro 1st gen, Asus Avivo, Thinkpad Tablet 1st gen, Dell Venue 8 and a Fujitsu-Siemens way back in 2009/10.
    I prefer a 10.5-11", 8 is too small and 12 is too big. I have a desktop pc and a laptop. I need a tablet to take my notes on handwritten. I tried my friend's MediaPad(?) 10" tablet, wasn't impressed with UI and pen.
    The FS was a good size, but way too slow for OneNote and pdfs. Surface was a good size too.
    Now, a Surface is way too expensive, so as an iPad. Don't know, should I just fork for a 2020 iPad Pro 11" to solve all this?
    General Questions.
    1. What is your budget? around $1000 Canadian
    2. Would you consider purchasing used/refurbished? yes
    3. Do you prefer a media/mobile tablet like the iPad, Windows tablet PC, or notebook convertible? i'm open
    4. What size Tablet PC would you prefer? 10.5-11"
    • 5 to7-inches
    • 7.1 to 10-inches
    • 10 to 13-inches
    • Above 13-inches
    5. Which country do you intent to purchase from [where do you live]? Canada
    6. Do you have any preferences to brand loyalty or dislikes? none
    7. How many hours battery life do you require? 3+
    8. What will be the primary usage scenario of this tablet? (Email/Web Surfing/Drawing/Word Processing/Entertainment/Notetaking etc) Notetaking
    I primarily use OneNote, but I'm open
    11. Do you intend on playing Games? If so please list. n/a
    12. Would you like to stream content through your home theater system? n/a
    Screen Specifics
    1. Any preference on screen resolution? n/a
    See the above linked FAQ for guidance n/a
    pen is a must
    Component Specifics
    1. What size Hard Drive and Memory do you require? Would you like expandable memory? n/a
    2. What sort of inputs do you require, if any? Would you like full-sized USB and SD card slots? Are microUSB and microSD ok? Do you require HDMI inputs? n/a
    Misc
    1. Other non specific items ~ please add other items you require not covered above? n/a
    2. Additional requests ~ anything other you wish to take into consideration?n/a
  2. JoeS
    6,464
    5,347
    Hi there, what kind of studying will you be doing? Just listening to lectures / reading books and taking notes? Or tech work including CAD or simulation etc? Any extensive typing involved, as in "do you need a keyboard, or is an on-screen keyboard enough?"
  3. ultra99
    154
    Hi. No CAD or simulation. Mostly listening to lectures, taking notes, annotating papers/slides. I'll always have a laptop and/or pc so most typing will be done on those.
  4. JoeS
    6,464
    5,347
    Well in that case, an 11" iPad Pro with pencil might do just fine. Check Apple's refurbished store if they have one in Canada. Why do you say a Surface is too expensive? SP7 "starts from CAD $800".
    Anybody else want to chime in? Seems like for up to CAD$1000 there will be tons of options.
  5. Cuberdon75
    273
    215
    Galaxy Tab S6, or the S6 Lite coming out any day now.
  6. jnjroach
    4,164
    1,626
    OneNote on Android is painful...much better on iOS or Windows. iPad Pro 2018 or even a Surface Go or Pro X, rumor is a Go 2 is on the horizon...
    JoeS likes this.
