Need a Tablet for Classroom Use
Discussion in 'What Tablet PC Should I Buy?' started by Benjamin Chin, Nov 24, 2007.
  1. MathTeacher
    MathTeacher Pen Pal - Newbie
    Hello -
    1. What is your budget? under $2500
    not sure what UMPC means, I have been using a Toshba tecra convertible and it works for me. It is a bit heavy for my taste but not prohibitively so.
    Mainstream
    USA
    no preference
    2 hours minimum
    Mostly for lecture/demo in the classroom- projecting notes, running software like Mathematica and Geometers Sketchpad, internet java apps. Also using Adobe Pro and Photoshop....
    I have been using Windows XP very happily and am concerned that some of my software like Geometer's SketchPad wont run with vista...
    see question 7
    not really
    Screen Specifics
    no preference,
    no preference
    See explanation below for guidance.
    indoor/outdoor
    Active
    Wacom
    Component Specifics
    I have a gig on my current tablet
    I need a CD/DVD rom player with CD burner
    yes
    Misc
    I need CD ROM writing ability and several USB Ports.
    I am using a docking station at work and not sure what the advantage is...
    I also need Bluetooth options as the projecting system in my classroom is about to go wireless
    I LOVE LOVE LOVE my tablet when it is up and running! My only frustration has been its tendancy to freeze up on a regular basis ( several times a day since I first began to use it) I suspect that it is a problem with this particular computer not toshiba tecra's in general, but I have been unwilling to give up my tablet to the tech department for the length of time it would take for them to resolve the issue.
    I have been using my school's tablet and am ready to purchase my own. Any thoughts would be much appreciated!!
  2. Benjamin Chin
    Benjamin Chin Pen Pal - Newbie
    65
    Reasonable expectation with generous budget.
    UMPC. It stands for Ultra Mobile Personal Computer. This category falls between PDA and ultra-portable 12.1" tablet / notebook. UMPC can be thought of as miniturised tablet / notebook with reduced performance, but substantially more powerful than PDA.
    I assume that your existing Tecra is your school property. It is a decent product ranked between the high-end Protege and the budget Satellite series. Your school obviously made a reasoned decision to go ahead with the Tecra which is durable and not too expensive. Sensible choice.
    It would be a good idea to let your IT department solve the problem. This is alot more cost effective than to buy a tablet on your own just to avoid a problem. The Tecra is already a trustable machine.
    However, if you see a real purpose to buy one you may like to consider the Fujitsu T4220; choosing the variant which starts from $ 2,119.00, with indoor / outdoor display.
    Click :
    http://store.shopfujitsu.com/fpc/Ecommerce/buildseriesbean.do?series=T4220
    The Docking Station, otherwise known as Port Replicator, saves you the trouble of having to connect / disconnect various cables like your desktop monitor, desktop keyboard, mouse, Wacom tablet, etc., from your tablet notebook.
    By having all those cables attached "permanently" to the Docking Station, all you have to do is simply park / dock your tablet notebook to that Docking Station and you have access to all those hardwares, at once. No need to repeatedly connect / disconnect from all those cables, each time and every time. You have a thoughtful school administration.
    (I use a Docking Station for my ThinkPad T61 too.)
