N-Act Software
Discussion in 'HP Slate' started by morales, Jul 13, 2011.
  1. morales
    morales Pen Pal - Newbie
    I just installed the n-act software from n-trig and it works quite well. It doesn't fix any pen issues, but it does add some nifty functionality items associated with 2, 3, and 4 point touch gestures/commands.
    Does anyone else have any opinions about it?
    I did find it odd that it wasn't factory installed, but then again, some might consider bloatware...
  2. ships10
    1,525
    180
    What is the release date?
    If it is the same old one from Nov 2010....it installs ok...but acts out
    most of the time.....Let us know your experience in about 2-3 weeks!
  3. Steve S
    8,844
    4,622
    As mentioned before, N-act is something of a work in progress. This is probably why it was left to the user to decide to install it or not.
    If you are having issues with N-act, be sure to contact N-trig and tell them about it ( N-trig ).
  4. morales
    So far so good for me. It's summer though and I don't use the Slate as much. I do like the big n-act buttons that pop up in their respective menus. I wonder if this will be the route Microsoft will take with Windows 8 to make it more "touch friendly"...
  5. stevedebi
    stevedebi Pen Pal - Newbie
    44
    Do you have a URL for the download?
  6. ships10
    1,525
    180
  7. ghost74
    ghost74 Scribbler - Standard Member
    205
  8. stevedebi
    44
  9. angelix
    angelix Pen Pal - Newbie
    92
    Hi Guys
    I installed this but its is playing weird, making my Slate quite unstable.
    I keep getting a message saying the Ntrig message board stopped working.
  10. Kr00zen
    Kr00zen Pen Pal - Newbie
    I dont know if this is your problem or not but I have my slate over clock and found that N-ACT runs better set at 150.I did have it set to 153 and was getting some unstablitiy. Also I added the on/off switches to the desktop which alows me to trigger it on or off
