My power switch just broke!!!
Discussion in 'HP Slate' started by ghost74, May 12, 2011.
  1. Steve S
    6,004
    1,770
    <<...I'm making the assumption that...the little injection molded plastic slider part broke...>>
    ...In which case you may be pleasantly surprised when HP returns your Slate...!
    <<...maybe if you rip off the slider part completely, you might be able to operate the switch...>>
    ...I agree; that's a good suggestion...
  2. revmike
    revmike Scribbler - Standard Member
    443
    58
    Just send the thing in and get it fixed. And when you get it back and reconfigured the way you like, back up your drive.
  3. telecomgeek79
    telecomgeek79 Pen Pal - Newbie
    68
    I can say Yes. This happened to me a while back. It was purely the Plastic Portion of things.
    After putting it in and out a couple of times, the plastic finally broke completely.
    I now use my leatherman "tiny" flat blade screw driver to turn on/un-hibernate the Slate.
    It's of course a pain. But hey, if all they are going to do, is put in another plastic piece in, perhaps they can send the plastic "due-hicky" (SP? :) ) and I can put it in.
    I originally opened a ticket with HP and was going to send it back. But right now, I am waiting for one more thing to break. Might as well get my "Problems x Time Slate is away from me" ratio a little higher.
    Good luck with getting it fixed. If you get them to send you a plastic power switch. PM me, as that would be awesome.
    Telecomgeek79
    Apple....naah, love One Note to much. :)
  4. ghost74
    ghost74 Scribbler - Standard Member
    205
    Well, I sent it in via FedEx return service.
    Stay Tuned
  5. ArtV
    ArtV Happy Camper
    18
    ****. Broken power switch for me too. As I am not in the States, returning for warranty is not an easy option....
  6. telecomgeek79
    68
    Maybe ghost74 can get them to send him a "Spare" one?
    Maybe a re-design with Titaniam or a Metal?
  7. ghost74
    205
    FedEx Man came to the house this morning. No one to sign so hopfully he will come back tomorrow when I'm home.
    BTW: I remember a posting a while back that mentioned "loose" power switches. Mine was one of the loose ones, I wonder if its related and only a matter of time before others experiance the same issue.
    ArtV was your switch loose from the beginning?
  8. ghost74
    205
    It appears that they replaced the entire silver bezel. All data is in tact.
    I'm good to go. Now where did I put that extended warranty information?
  9. Steve S
    6,004
    1,770
    <<...It appears that they replaced the entire silver bezel...>>
    ...The switch slider is probably an integral part of that sub-assembly.
    The slider itself is probably not available (or, more properly, can't be replaced) as a stand-alone part...
  10. ArtV
    ArtV Happy Camper
    18
    My slider switch was also loose from the start.
    The switch is a very flimsy piece of plastic inside, and simply snaps into place with a guide. It certainly looks like a 2c part that could be replaced by snapping a new one in place - not sure why they replaced the entire bezel. There are two very small "legs" on the inside of the slider switch that rest over a lever inside the device. I am now using a plastic "toothpick" from my Victorinox pocketknife to operate the lever/switch - the toothpick slides nicely next to the stylus in the case and travels with me. Not glamorous, but it works.
