My Experience Might Help You
Discussion in 'Professions' started by Mikejody, Aug 11, 2016.
  1. stoneseeker
    3,604
    1,056
    Maybe, but why when the app crashes does the system completely replace my file with a blank document everytime?
  2. siddhartth
    siddhartth Scribbler - Standard Member Senior Member
    830
    300
    That is not supposed to happen. Which-apps are you using.
  3. stoneseeker
    3,604
    1,056
    It's happened with Sketchbook Pro and Infinite Painter. 3 times the document crashed and when I try to open the file again the preview looks cut off, (like a sliver of the image is shown in the thumbnail) and when I open it a blank canvas has taken its place. I guess that's what I hate about Android is usually you have backups you can resort to on Windows, but in Android everything is supposed to be automatic, so when it fails, it fails hard.
  4. siddhartth
    830
    300
    i will advice you to return the tablet and seek replacement because that has never happened with me on android.
  5. Kumabjorn
    4,311
    2,382
    @stoneseeker Do you have Dropbox installed? If do you could start by saving a new canvas to it (share to be more precise) and then set Dropbox to upload every five minutes or so. At least you should have most of your canvas available. Another trick is to open Task Manager and free up RAM, this will close your paint program as well, but when you open up again your canvas should be there (provided they've coded it according to Android guidelines).
