mWh of modular bay battery
Discussion in 'Asus' started by deek, May 7, 2008.
  1. kritzler
    kritzler Pen Pal - Newbie
    27
    Hi there. Just bought a bay batterie for my R1E. I thought it has the same capacity than the normal batterie (52000mWh), but it only has 36000mWh (shown in Notebook Hardware Control). Is this normal or does it give an other bay battery with more power?
  2. hamud
    hamud Pen Pal - Newbie
    94
    it has 36000mWH not 52000 and all modular battery has less capacity than the normal battery so that's very normal !!
  3. kritzler
    27
    Ah, thank you. So i will keep it.
  4. deek
    deek Scribbler - Standard Member
    135
    The numbers you guys have for the batteries are correct but I do believe that the units are mAh (mili Amp hours) . As you use more wattage (CPU load greater, disk writing, etc) the amount of current increases.
Similar Threads - modular battery
  1. lovelaptops
    1,041
