Multitouch or Superview
Discussion in 'Lenovo (IBM)' started by bkrosco, Jun 19, 2007.
  1. bkrosco
    bkrosco Pen Pal - Newbie
    I currently have a Superview on order (SXGA screen). I am still going back and forth in my mind though as to whether or not multitouch would be better for me.
    One of my concerns is if I do not get the multitouch screen, is there an issue with resting my hand on the screen while writing? Will that screw it up?
    I do a lot of remote support so I want the higher resolution so that my client's screen will fit inside of mine without having to scroll so much.
    Thanks for any input.
  2. wermerskoch
    wermerskoch Pen Pal - Newbie
    51
    Here's a pretty extensive video review of the multitouch screen:
    http://www.gottabemobile.com/LenovoThinkPadX60TabletPCMultiTouchAndUltrabase.aspx
    To answer your main question about writing on the multitouch screen, no it will not mess it up. It senses when you are using the digitizer, and turns off the passive touch screen accordingly. The guy in the video talks about that at great length. I'll be getting an X60 with multitouch in the next few days, can't wait! :D Having the ability to navigate with my finger, if I should so desire, was worth the lower resolution to me. Especially if you're just reading and listening to some music. Hope this helps.
    Warner
  3. thaluckyspoon
    thaluckyspoon Scribbler - Standard Member
    481
    I had no idea which one I wanted; every single day I woke up with a different opinion. I ended up having my girlfriend draw out of a hat for me. When she pulled out 'Super view- no multi touch' I felt sad and that made me realize that I truly wanted the multi-touch.
  4. SFWrtr
    SFWrtr Science Fiction Writer
    Perhaps multi-touch isn't a deciding factor. Having bought the multi-touch screen, I will say that being able to poke the screen occasionally to press a button is good. You're going to reserve writing to the pen though.
    What you might want to think about is the Multi-view part of the screen. The lap top is very usable outdoors if you get the multi-touch, multi-view screen. From what I have heard, it has less trouble with smudges than the superview and works better outdoors. The res is lower, however. I like the mt/mv, though. I've posted pictures on the blog page of my X61 Tablet page (see my signature below).
  5. sregreb
    sregreb Pen Pal - Newbie
    29
    I can't believe that Multitouch should require that much pressure. I will do plenty of web surfing, and want to use touch for that. I hope there is some further calibration that can be done so we can use it like the videos we have seen on GBM. At least that's what I want to believe....
  6. Charles P. Jefferies
    Charles P. Jefferies Administrator Super Moderator
    390
    54
    I went for the SXGA+ because I wanted the screen real estate it offered. XGA is a low resolution and I can't deal with it - I feel too limited by low resolutions in what I can do.
  7. thaluckyspoon
    481
    If you check out online videos of other users the finger input looks much better than SFWrtr describes. I see no screen wobbling from the demo's.
  8. ensoll
    ensoll Pen Pal - Newbie
    It sounds like he is trying to use the meat of his finger to press things. Using a fingernail gets much better results on the touch screens I've tried.
  9. thaluckyspoon
    481
    Yea it sounds like it to me as well. I use the tip of my fingernail here at work on our HP Touchsmart PC. I don't see a reason to even want to have the ability to use the fat of your finger; It only makes the screen greasy and shortens its life span.
    If you haven't decided on multi-touch yet imagine this. You lose your pen and the shipping will take 3 business days. With multi-touch you can grab anything and write with it almost (but not quite) as well as you could with the digitizer.
  10. sregreb
    29
    Good point. I guess I should have considered this before, and it's probably a stupid question, but how do you RIGHT-CLICK in tablet mode? With the little button on the pen? Obviously you can't with touch.
