Multitouch driver installation error
Discussion in 'HP TouchSmart TM2 (Wacom)' started by Oliver Beyer, Feb 26, 2010.
  1. Oliver Beyer
    Oliver Beyer Scribbler - Standard Member
    126
    Hi ther,
    I have done a clean install of Win 7 and everything works fine. The only thing I'm unable to install are thos multitouch drivers offered here. They just give me an error when I try to run their setup.
    Is there a trick to it? Has anyone came across that issue?
  2. satchmo0016
    satchmo0016 Pen Pal - Newbie
    Can you "multi-touch"? Try zooming in or out by pinching the screen in I.E.
    If yes;
    You already have the drivers installed and that particular install package gives said error upon inspection, realizing that the drivers are already there.
    If no;
    Perhaps there was an error installing, but I'd say that you probably already have it installed.
    S
Similar Threads - Multitouch driver installation
  1. NeoEevee
    816
