Motion C5V
Discussion in 'Motion Computing' started by devilsrogue, Oct 13, 2013.
  1. Adidas4275
    Adidas4275 Pen Pal - Newbie
    33
    Thanks for posting these pictures. Not a lot of data on these out there.
    I got 3 for $150 on eBay and for that price they are amazing machines!
    I picked up a 256gb msata with a 1.8" adapter to swap into it and run windows 8.1 on it. Just wish it was touch :)
  2. deere245
    deere245 Pen Pal - Newbie
    Glad I could help...I found a service manual for the C5v but the file must have been corrupt. I tried several times but it was always unreadable......
    Oh well at least I found these photos to share..
    I really like my C5v...I run Onenote and Autodesk Sketchbook // Copic edition. It's great for quick drawings or putting notations on photos. It's relatively waterproof so I don't have to worry about the rain.
  3. Adidas4275
    33
    I am trying to use mine outside during the winter for soccer analysis, should be fun :)
  4. Adidas4275
    33
    So i got my c5v up and running with a 128gb SSD and windows 8 on it. it works great, other than the relatively small resolution screen and the frustration of not being able to use your finger :)
    The only problem I am running into is heat and lower batterylife than i expected.
    according to coretemp my CPU is running between 50-60 degrees C idle and up to 70 degrees load. it is the i5 520um CPU is this normal? It seems a little hot to me ;(
  5. deere245
    I never measured my temps..but they never seem hot enough for my concern.
    Does the fan come on?
  6. Adidas4275
    33
    It does, for a little bit when I launch a program or something CPU intensive.
    Just noticed a decent amount of heat lower right and upper left sides.
    I know newer ivy bridge and haswell CPUs do a better job of throttling to lower P states just wanted to make sure I wasn't missing a bios updates (didn't see one on motion computing a site) or a w8 intel driver.
    Thanks for responding
  7. deere245
    There was a post asking me for better quality pictures. It was deleted for some reason...I don not know why, but I did my best with the photos I have.
  8. CameronTM
    CameronTM Pen Pal - Newbie
    So I bought 2, 4GB sticks and was quite easily able to put it into my C5v using the photos and instructions from here and elsewhere. I took the 2GB out and put it into another C5v, so I have one with 8GB, one with 4GB and another with the initial 2GB. There is definitely a noticeable difference between each of them. I am very happy with my 8GB and how easy it was to do. Much easier than the C5. In Windows 7 64-bit it says I have 7.8 GB Usable.
  9. CameronTM
    I paid $167.02 on eBay for the C5v and $69.99 on NewEgg for the 8GB of RAM, so for less than $250 I have a great running tablet. I do wish for better resolution, but you get what you pay for.
