Mostly Comic Books
Discussion in 'What Tablet PC Should I Buy?' started by matthew roscetti, Feb 5, 2018.
  1. matthew roscetti
    matthew roscetti Pen Pal - Newbie
    Hi. I'm a comic book artist and illustrator. I also do graphic design like brochures, signs, and logo work.
    I currently have a Fujitsu T900 that is starting to die. Some of the keys don't work, the USB port is fried, the charger is missing ( my kids charger fits but sharing is a pain especially because I'm out of the house a lot).
    So time to upgrade.
    Here's what I'm hoping for
    What is your budget?
    $400-$700
    Yes
    Tablet PC preferred but open to other options
    • 5 to7-inches
    • 7.1 to 10-inches
    • 10 to 13-inches
    • Above 13-inches
    10 to 12 inches
    USA
    No
    Probably about 6 ish or more
    Art work. Netflix and chill
    Windows 10
    Clip Studio Paint, Photoshop, Illustrator, Word, Acrobat, Chrome.
    No
    I suppose but not really
    Screen Specifics
    1080 or better, I guess.
    No
    Must be pressure sensitive
    Component Specifics
    Probably 256-512 GB
    I'm not sure what the programs I use actually take up. I fear 128 is way to little.
    Expandable could help.
    Full sized USB would be nice as I use wireless mouse with a dongle connection regularly. I suppose a Bluetooth connected mouse if no USB could work. Also eyeballing the Wacom Expresskey remote which, if I'm not mistaken people have used with off brand products like the Surface Pro by installing the proper drivers. If I can make it work.
    Would also like to use an memory stick or external drive for back up and file transfers but I can think of many options such as adapters to make everything work.
    Upgrading to USB-C like my phone could be handy but not required.
    Misc
    Really curious what my set up actually requires as far as ram and storage space? Which is why I think I'll need 256 gb minimum but maybe I don't?
    I'm pretty sold on a HP elite X2 g1 with 8 GB ram and 526 GB SSD which are coming in around $600-$700 on eBay. Some used/refurbished and some are actually new in box (or so they claim).
    My brother has a Galaxy book that he just bought but that's too rich for my blood but it sure is nice. Maybe I can find something that make me happy and be a stellar device?
    Looking at Surface pro's in various generations and configurations but hard to find what I want (ie: it has windows 8, is missing keyboards, no stylus, low ram or storage, just right but a touch too expensive.)
    Been looking at Lenovo's, Toshiba's, Dell's etc. But my head is starting to spin trying to keep the options organized in my brain.
    Thank you all for your help
    -Matt
  2. thatcomicsguy
    3,291
    2,346
    DaniJoy likes this.
  3. darkmagistric
    2,988
    2,146
    The Galaxy Book 10.6 is in your price range. Lite on Ram and storage (4GB of Ram, and 64GB or 128GB, and only) but for storage you do have a MicroSD Card slot which helps. Photoshop....won't run that well, but Clip Studio Paint runs flawlessly on it, and the S-pen (with grey nib) beats the Surface Pen or any of the MPP pens.
    Main drawback though...if you intend to get a Wacom Express Key Remote.....its wireless USB Type A....not C....so you would have to use it with a dongle......which makes the Express Key remote...kind of cumbersome since you're going to have this thing jutting out of the USB-C port. Its far more limited, but for this reason I prefer using the Surface Dial with my Book since its bluetooth based.
    thatcomicsguy likes this.
  4. Starlight5
    Starlight5 Yes, I'm a cat. What else is there to say, really?
    676
    221
    @matthew roscetti check out Thinkpad Yoga 370 and Toshiba X20W. Elite X2 1012 G1 is overall OK but CPU & GPU are on the weak side, while the G2 will cost you much more; 1011 is not even worth considering IMO. Wacom Express-thingie is crazy expensive; a compact Bluetooth gamepad can do the same or better for a fraction of cost and won't limit you to USB-A devices.
  5. matthew roscetti
    Thanks everyone.
    That Toshiba catches my eye at a slightly lower cost then the Lenovo. It originally comes new with a pen, correct? I see a few decent priced refurbished machines on e-bay but none make mention of the stylus
  6. matthew roscetti
    I'm curious how the X2 gen 1 stacks up against the Fujistu T900 that I currently have performance wise? Improvement or worse?
  7. Starlight5
    676
    221
  8. matthew roscetti
    Hi everyone. I ended up buying a Samsung Notebook 9 pro 13.3”. Haven't had too much time tonplay with it but impretI'm happy. Wacom EMR. S pen is a but tiny but the stylus from my Fujistu works with it and that's thicker. I got it at Best Buy, I bought an "open box". So it was about $400 less then list price. I got it for $678.99. 8gb ram and 256 gb SSD. i7 chip.
    https://www.bestbuy.com/site/samsun...ffcode=pg198997&ksdevice=m&lsft=ref:212,loc:2
    Starlight5 and thatcomicsguy like this.
