most current graphic card driver for tx1000?
Discussion in 'Hewlett Packard' started by Dalek G, Oct 8, 2007.
  1. Dalek G
    Dalek G unpaid scientific advisor
    Anyone know what the most recent (stable) graphic card driver for the tx1000 series is?
    I'm having a resurgence of problems getting my notebook to go into sleep mode when I press the sleep button (it doesn't hibernate at all anymore, so I've given up on that), and I think the graphics driver is the culprit. My driver is dated 2/27/2007 and is version 7.15.10.9815.
  2. feffrey
    feffrey Pen Pal - Newbie
    50
  3. StephenGillie
    StephenGillie Pen Pal - Newbie
    90
    For the hibernate thing, try deleting the hibernate file:
    Disable hibernate
    goto c:\
    set folder options to show hidden files and folders
    hiberfil.sys should be on c:\
    delete it
    enable hibernate
    try that and hibernate *might* work. I've had to do that from time to time when hibernate failed on me.
    Right now I'm using an unofficial driver from http://www.tweakforce.com/
  4. Dalek G
    I tried the driver at hp.com, its the same one. No idea why they say its 5/2007.
    Hibernate works just as often (or not) as sleep, I went to the command prompt and did "powercfg -h on" to make sure.
    I let the computer sit while not sleeping/hibernating, and after about 10 minutes I got a bluescreen;
    DRIVER_POWER_STATE_FAILURE
    Problem signature:
    Problem Event Name: BlueScreen
    OS Version: 6.0.6000.2.0.0.768.3
    Locale ID: 1033
    Additional information about the problem:
    BCCode: 9f
    BCP1: 00000003
    BCP2: 83992B98
    BCP3: 855793D0
    BCP4: 83FF8B20
    OS Version: 6_0_6000
    Service Pack: 0_0
    Product: 768_1
    The closest I got to a solution was a very vague mention on microsoft.com.
    So, evidently, I have to wait until Vista SP1 to maybe get it resolved, unless I want to gamble with a "special" request-only hotfix. meh.
    The irritating thing is that sometimes sleep and hibernate works. It seems to fail if the notebook has been on and in use for a while...so if I want updates to work properly I have to do a fresh reboot so it goes through the restart cycle correctly.
Similar Threads - current graphic card
  1. Worzyl
    907
