More than 2GB in R1F?
Discussion in 'Asus' started by deek, Jan 8, 2008.
  1. ChrisC
    ChrisC Pen Pal - Newbie
    Has anyone tried putting more than 2GB in an R1F? Does the machine recognize it under Vista or XP?
  2. alphaswift
    923
    Under XP and Vista, a user can only see 3 GB of memory. The motherboard will take 4 GB ( 2x2GB) of memory. That said, 2GB chips are VERY expensive. Like about 6x more expensive than a 1 GB stick.
  3. P8RSON
    5,189
    Correct...
    Unless you have 'pots' of cash to spare, 4GB is a level most can only dream of.
  4. ChrisC
    OK, but at least it's possible. I just wanted to be sure that it's upgradeable, in a year or so, when memory should hopefully be cheaper.
  5. sandwalker
    sandwalker Pen Pal - Newbie
    The 2 gig ram sticks just aren't worth it yet. Instead just max it out with 2 gigs of ram + a 2 gig SDRAM. Vista's Readyboost feature uses that to speed things up. I just got it yesterday and notice a big difference in system speed, plus it's inexpensive.
  6. P8RSON
    5,189
    But not an option for non-vista machines sandwalker.
  7. chinesefireball121
    376
    True for XP and and 32 bit Vista. Although under 64 bit Vista how much RAM the OS can recognise is dependent on the version you have:
    Home Basic - 8GB
    Home Premium - 16GB
    Business, Enterprise, Ultimate: 128GB
  8. P8RSON
    5,189
    That's just the software limitations chinesefireball121.
    What you have to consider is also the Processor's limitation, which is the deciding factor here.
  9. chinesefireball121
    376
    Of course. I was just pointing out that Vista isn't limited to using 3GB of RAM as was suggested. It is as you say, the motherboard is the limiting factor.
  10. sunny
    sunny Pen Pal - Newbie
    Have you tried it yourself? Or can any dealer or tech-expert verify this?
    I am asking because most tech specs on the net say max 2GB, but I do not really see a reason for this.
Similar Threads - More
  1. desertlap
    1,475
  2. Bishop
    1,508
