Missing OSK
Discussion in 'Windows 10' started by ayle, Aug 1, 2015.
  1. ayle
    ayle Pen Pal - Newbie
    So I've upgraded my S3 to W10 but at some point explorer crashed hard and i wasn't able to open the start menu anymore. And the task bar icon for the keyboard disappeared in the process too. So I forced a restart and since then my keyboard icon is gone. Since I haven't bought a type cover yet, I can't type anything. How do I get the icon back?
  2. DRTigerlilly
    7,595
    750
    301
    try switching to tablet mode. Had the same problem on my wt310
  3. ayle
    Alright, I'll try that if it reoccurs, once I've upgraded again. Will Microsoft update the recovery image to W10? Having to downgrade to 8 then back up to 10 when something goes awry will get old quickly....
  4. DRTigerlilly
    7,595
    750
    301
    Once you're upgraded and activated the key is tied to your machine, you should be able to use the media creation tool to make an iso and do a clean install.
  5. ayle
    Thank you for that. And how do I change the password lock timeout to immediate? Currently if doesn't ask for a password after I wake the screen up and I couldn't find the option in the control panel.
  6. DRTigerlilly
    7,595
    750
    301
    right click on desktop go to personalize, go to lock screen along the left side, choose screen saver settings, Choose a screensaver, the appropriate timeout and check on resume display logon screen.
  7. beyondthetech
    beyondthetech Pen Pal - Newbie
    18
