Missing ExpressCard on T4210...
Discussion in 'Fujitsu' started by rob1116, Jun 25, 2006.
  1. rob1116
    135
    I'm new to tablets/notebooks in general... maybe I am missing something, but it doesn't seem like I would have much use for a laptop expansion slot (PCMCIA or ExpressCard). I mean, other than a wireless broadband card (I won't be subscribing to such an expensive service in the near future anyway), what can you do with this thing that you can't do easier/cheaper with some other I/O method?
    What I am getting at is, the T4210 is without the newer ExpressCard option... and I'm assuming the PCMCIA is going to fade out relatively fast. Should I worry about this for any reason?
    What do you guys/gals use these expansion slots for anyway? I mean, the T4210 has integrated wireless a/b/g and bluetooth (which I'm assuming means they are actually built-on, not expansion cards), so what will I be using it for?
  2. butanamine
    butanamine Pen Pal - Newbie
    34
    I don't know what most people use them for, but I do know you can use them for sound cards.
  3. Brian
    1,305
    Today, I'd rather have PCMCIA than ExpressCard. There are hundreds of expansion cards for PCMCIA and less than 5 for EC.
  4. rob1116
    135
    hmm... well, that will surely change though, no?
    Well, either way, I can't find many accessories in these interfaces that my prospective laptop doesn't have built-in already, or that I couldn't just as easily find in USB. Feel free to correct me if I'm wrong.
  5. Gautam
    Gautam Moderator
    484
    uses for the PCMCIA/ExpressCard slot are
    for soundcards and TV tuners. I have also used it for extra USB2.0 and Firewire ports.
  6. Brian
    1,305
    Aside from air cards, you can get about everything else via USB or included.
  7. P8RSON
    5,189
    Agree....
    Including a USB 2.0 to 4-PIN Firewire IEEE 1394 cable.
    Which if you think about it is the ideal solution for models that are now shipping with no firewire port.
Similar Threads - Missing ExpressCard T4210
  1. Lunafox
    1,468
