Microsoft Surface 3 or Microsoft Surface PRO 2
Discussion in 'What Tablet PC Should I Buy?' started by SOLA, Aug 7, 2018.
  1. SOLA
    SOLA Pen Pal - Newbie
    Hi, could someone suggest me which one to get.
    Surface 3 is like 100 eu more than Surface PRO 2 but they say that surface pro 2 has much better CPU.
    Is that true?
    What is your suggestion?
    Thanks
  2. freewilly
    freewilly Pen Pal - Newbie
    88
    The Surface Pro 2 also has a Wacom digitizer which, as far as I'm concerned, is a huge plus. Also, the Pro 2 has an SSD, which is wayyy faster than the EMMC storage of the Surface 3. The CPU should be far speedier too and fan cooling helps reduce throttling. Also, Intel XTU can be used to undervolt the SP2.
  3. Shogmaster
    4,265
    1,505
    Surface Pro 2 is a much better machine, but for one factor: Battery life. You can't beat S3's Atom Z8700 sipping its battery. Surface Pro 2's Haswell ULV i5 can't compete on that front. But then again, I couldn't bear to suffer through the Z8700 + eMMC + NTrig combo. It was torture.
    Let me propose a third option: Something like Lenovo Helix 2nd gen: You get the decent performance of the i5 Haswell (especially if you opt for the 5Y70 CPU upgrade) and Atom like battery life along with an excellent Wacom EMR pen performance like the Surface Pro 2.
    https://www.cpubenchmark.net/compar...tel-M-5Y70-vs-Intel-i5-4200U/2506vs2382vs1947
    If you are lucky, you can score a 8GB/256GB 2nd gen Helix with the ultrabook KB dock for about the same price as 8GB/256GB Surface Pro 2 with it's keyboard.
  4. bloodycape
    2,773
    411
    To be fair there is the option of the type cover that has a battery that works with the SP2.
  5. Shogmaster
    4,265
    1,505
    It would help but helix 2nd gen ub kb dock also has battery in it iirc. 4200U vs 5Y70 is no contest for battery life anyways.
