Microsoft Garage killing Snip
Discussion in 'Windows 10' started by convergent, Dec 13, 2017.
  1. convergent
    405
    71
    https://www.microsoft.com/en-us/garage/profiles/snip/
    I love Microsoft Snip on my Surface Pro. So easy to grab a screen grab, picture, or white board... then annotate it if I want, and its already in the clipboard. I was just recommending it to someone on my team and they pointed out that the above link says Microsoft is killing it in May 2018.
    Can anyone recommend a good alternative? The thing about Snip is that its so quick and easy to use... no friction. Some of the tools are way more feature packed but more complicated to use.
  2. Kumabjorn
    4,455
    2,636
    It will be removed from my computer as well?
    I use it at least every week, I don't want to lose that.
  3. jnjroach
    4,087
    1,490
    How about the built in Snipping Tool?
    DRTigerlilly likes this.
  4. Kumabjorn
    4,455
    2,636
    Lacks the annotation features and ease of use.
    siddhartth likes this.
  5. Shiratori
    Shiratori Pen Pal - Newbie
    50
    25
    It won't be removed from your computer; they'll just remove the download links. I'm probably going to put a copy of the installer on my OneDrive for when I need to install it in the future.
    siddhartth and Kumabjorn like this.
  6. Kumabjorn
    4,455
    2,636
    Where do I find that, I'd like to do the same.
  7. Shiratori
    50
    25
    https://mix.office.com/Snip
    There you go. :)
    Kumabjorn likes this.
  8. convergent
    405
    71
    Are you sure... the link said it would be removed and you'd lose all your saved snips.
  9. Shiratori
    50
    25
    You're right. I missed that. I guess the app must have a built-in expiry date as it was a MS Garage project. That's a shame as it's quite a useful addition. At least I can get most of the functionality in the Screen Sketch part of Windows Ink on my machines as they're all on Windows 10.
  10. Kumabjorn
    4,455
    2,636
    Meaning you won't be able to install it after its expiration date?
