Memory and ReadyBoost?
Discussion in 'Asus' started by comet128, May 21, 2007.
  1. jlg
    jlg Pen Pal - Newbie
    24
    Folks,
    has anyone tried a Patriot Extreme Performance 4GB Secure Digital (SD) Flash Card Model PEF4G133SD for use as a ReadyBoost drive?
    I'd like to know if it will work before actually ordering it.
    Also, any opinions as to good 1x1GB 200pin DDR2 667 memory?
    I want to upgrade to have 2GB for Vista.
    Thx!
  2. jlg
    24
    Also, what memory is in the system now -- PC 5300?
  3. jdwilson
    184
    I just ordered another 1 GB from zipzoomfly for $27 (after rebate).
  4. jlg
    24
    Just to update this thread, I actually got a transcend 4Gb SD card, and it works great with ReadyBoost.
  5. deepak
    156
    for memory i would suggest OCZ or corsair, they are a bit expensive but are pretty good performance.
  6. jdwilson
    184
    The $27 memory I linked to above is Corsair Value Select . . .
  7. deepak
    156
    wow, thats good! too bad i can't get it for that price in toronto.
  8. comet128
    comet128 Asus R1f User
    18
    Hi jlg,
    I don't know if you are in the states, but I purchased a 1gb PNY Optima Memory ddr2 667mhz 200pin notebook memory module for $60 on sale from Staples. Reg. price was approx $100 or more. Check out Staples, J&R, & Compusa for good deals.
    Good luck!
    Comet128
