many websites don't load with vista/tablet
Discussion in 'Hewlett Packard' started by dranpsych, Jul 4, 2008.
  1. be77solo
    674
    171
    yeah, windows update says there are no new updates, ran it several times... have no idea, but nbc.com comes up as "cannot display"
  2. ThinkGoofy
    ThinkGoofy Pen Pal - Newbie
    I don't know if it's just me, but when I try to make youtube video into fullscreen i only see half screen of black and half of gray divided in diagonals. Does anyone know the solution to this problem?
  3. miner
    miner Scribbler - Standard Member
    276
    Uninstall and update flash from adobe's website.
  4. ThinkGoofy
    Hmm, haven't tried that but it works now. I went into display settings and lowered the color settings to 16bits. I am going to reinstall flash and see if it works with 32bits.
    Edit. Reinstalling flash makes it work on 32 bits. Thanks miner. :D
  5. be77solo
    674
    171
    ok, just uninstalled Flash, and reinstalled, and nbc.com still won't load... very annoying
  6. ScotchtapeLoser
    ScotchtapeLoser Scribbler - Standard Member
    182
    is NBC.com solid white or is something loading but it never finishes?
  7. be77solo
    674
    171
    It comes back with the white, "Internet Explorer cannot display the webpage" next to the big blue I.... The standard screen that appears when you try and connect and have no internet connection... only i do, and I'm posting this as I try to load nbc.com... wierd
  8. be77solo
    674
    171
    And I'd say it's the website, but I've tried it on other computers and it's loaded perfect.... the only two that won't load it are my TX2110US and my new TX2500...
  9. wbaqai
    wbaqai Pen Pal - Newbie
    under internet options, under advance tab, reset it. It worked for me.
  10. kwhy
    kwhy Pen Pal - Newbie
    28
    nbc.com won't load on my tablet...
    after doing some research it seems someone found that the nbc website is re-directing tablet users to the mobile site or possibly the wap website. This is probably based on the User Agent property IE gives off to the website and the bad coding on their end.
    a workaround is..
    you can try
    http://www.nbci.com
    or I found this (untested)
    [cut off web]
    This is a band-aid but remove the following registry key, delete the IE cache, and close all browsers and http://www.nbc.com starts working again.
    HKLM>Software>Microsoft>Windows>CurrentVersion>Internet Settings>5.0>User Agent>Post Platform>Tablet PC 2.0
    [cut]
    this will just probably remove tablet pc 2.0 from the User Agent variable when connecting to websites...
    for example right now my user agent is set at
    Your User Agent is: Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; Media Center PC 5.0; .NET CLR 3.0.04506; Tablet PC 2.0)
    deleting that last bit should take off Tablet PC 2.0
    hope that helps..
