Making OS icons bigger
Discussion in 'Hewlett Packard' started by Crito, Aug 2, 2008.
  1. cdkg
    cdkg Pen Pal - Newbie
    Is there a way to make the Icons bigger on my tx2500 vista laptop? The idea is I would like it to be more touchscreen friendly.
    I tried changing the screen resolution 600x800 which did exactly what I wanted it to do but I could'nt get the screen to calibrate on the top left side so it didnt end up being that useful.
    Any help would be greatly appreciated.
  2. cloudnine
    cloudnine Scribbler - Standard Member
    158
    ctrl + mouse wheel up
    or
    Click view button arrow on any window and drag the slider to desired size.
  3. Nyture
    Nyture Scribbler - Standard Member
    142
    Right-Click Desktop -> Personalize -> Display Settings -> Advanced Settings
    My laptop doesnt have it, but I know when I was using XP w/ a different gfx card I had the option to change the DPI setting without changing the resolution, which in turn leaded to larger icons for a lower DPI. If your computer has the option Id try it out. I think standard is 96 DPI
  4. gordoncahill
    528
    For the desktop icons just right click on the desktop>view>large icons. For the taskbar right click on the desktop>personalise>windows color and appearance>open classic appearance properties and you can change the icon size here.
    Gordon
  5. Crito
    Crito Scribbler - Standard Member
    105
    First thing I did to Windows on my tx2500z was switch from 96 to 120 DPI.
    If you right click desktop and select personalize, there's a link in left panel to scaling applet.
