MacBook Pro and iPad replacement
Discussion in 'What Tablet PC Should I Buy?' started by Nicholas8681, Jul 4, 2018.
  1. Nicholas8681
    Nicholas8681 Scribbler - Standard Member
    195
    50
    General Questions.
    1. What is your budget?
    $1600
    Yes.
    Windows detachable or 2 in 1
    • 13-inches and above
    United States
    Not really.
    At least 8
    Web development
    Prototyping in Protopie
    Digital artwork
    See thread title. I'm wanting to leave the multi-device world of Apple.
    Affinity apps
    Visual studio code
    Linux subsystem on windows
    Various paint applications (ie. Leonardo, etc.)
    OneNote
    Probably just something like League of Legends.
    Maybe Fortnite
    Sure. Not a requirement.
    Screen Specifics
    Retina level
    I could be occasionally remote at a cafe, and would need it to be bright enough for that.
    Really I've found any of the recent AES and N-trig are adequate.
    Component Specifics
    At least 256gb HD and 8gb RAM
    I'd like full-sized USB
    USB-C with Thunderbolt 3
    Audio jack would be nice.
    Misc
    I do like the Surface Book 2. But I worry about it's reliability. It fits most of my requirements, but I've read many places about it's hardware failings, and I had a recent lack of caring from Microsoft about a New SB I bought that failed.
  2. Nicholas8681
    195
    50
    I'd also add that I have dealjng with bloatware. I've always found all the brand specific extras as annoying applications.
  3. Marty
    2,669
    2,034
    Brave man. I thought Apple had made even contemplating this nearly impossible for mere mortals. ;)
    Well since you code and want a retina screen with gaming on the side, you pretty much need a discrete GPU with a large 4K screen and a solid keyboard.
    At that price point, I'd recommend these two options:
    Splurge a little, and you get the XPS15 2-in-1 ($2000) but I'd wait for a sale on that one...
    kneehowguys likes this.
  4. cleft
    313
    55
    @Nicholas8681 My situation was roughly identical to yours. I needed to replace a workstation laptop and a Surface Pro 3, and ended up purchased a ThinkPad Yoga X380.
    I've been with the X380 for only ~2 weeks, but so far I'm really content with this 2-in-1. It's light, serve all of my fundamental needs (coding, note-taking, reading, drawing). And as a bonus point, the palm rest area does not get warm when under load.
    However, battery life might not meet your requirements. I've got ~6-7h without power adapter.
    Starlight5 likes this.
