M7 Slip Case/Sleeve
Discussion in 'Toshiba' started by cutie4032, Jul 21, 2006.
  1. cutie4032
    cutie4032 Pen Pal - Newbie
    Just ordered my M7 yesterday.
    Anyone know of any good sleeves or slip cases for the M7? The 14.1" widescreen is proving to be pretty difficult to find accessories for.'
    Thanks :p
  2. Lbgrowl
    Lbgrowl Pen Pal - Newbie
    22
    Yes someone please answer this one...I'm looking for a good, cheap slipcover for my R25 14.1 widescreen
  3. jritter
    jritter Pen Pal - Newbie
    42
    here cutie- its inexpensive but holds the m7 nicely. i just picked one up today... it says 15.4 but it is just the right size for the m7... if you actully measure the screen bezel including the glass for the wacom digitizer, these tablets fall into the 15.4 category.
    So to all of you looking for a case for your m7/r25... it is actually a 15.4 laptop chassis!!!!! :)
  4. cutie4032
    THANKS!!!
    This looks perfect actually. I'm def going to Bestbuy to pick one up. :p
  5. cutie4032
    Hey just picked one up.
    Looks good so far, guess I'll see how it fits when I get my M7.
    The dimensions on the website are off though... The exterior dimensions are more like 14.5" x 12.25" x 1.25"
    It is slim and the padding feels good enough for it though... def not bad for 10 bucks.
    Thanks again :)
  6. jritter
    42
    No problem. I just got to really test it out on the plane today and its works great... the only problem i have more or less is with toshiba than the slip case... That over-sensitive latch of the m7 let go and the machine fired up while still in the slip case. My tablet woke up out of hibernation and started overheating. just don't leave the zippers directly in the center over the latch =-/
  7. cutie4032
    Hmm... thanks for the advice. Yeah, the overheating thing def doesnt sound like a good idea.
  8. cutie4032
    Hey guys I found another one that fits better. It is the Case Logic slip case found at Bed Bath and Beyond. The padding seems to be decent and it fits nicely. Its also a bit shorter than the other case so it fits better in my bag. :p
  9. FLeone
    FLeone Pen Pal - Newbie
    Hello to you all,
    I'm having the same problem at the moment, but can't find the two sleeves mentioned above. Can someone give me more detailed information on sleeves that will fit my tecra m7? Thanks a lot in advance!
    kind regards,
    Frank Leoné
  10. FLeone
    Anyone? I really need it, my tecra m7 is getting scratched quite fast...
    Thanks in advance again,
    Frank
