Lost pen function
Discussion in 'Asus' started by P8RSON, May 6, 2007.
  1. Kayla
    Kayla Pen Pal - Newbie
    47
    I installed a new driver for my pen because my eraser would stop working in onenote. After I installed this driver I lost all function of my pen. I uninstalled the driver and reinstalled a touchpad driver hoping it would work, but my pen still does not work. Any ideas? I don't know what drivers to reinstall. Thanks!
  2. alphaswift
    923
    Was the eraser only not working in Onenote?
    What new driver did you install?
  3. Kayla
    47
  4. P8RSON
    5,189
    Which option did you choose.... WinXP Tablet Ed or Vista.
    If you chosen the right one, try this version from the European site.
  5. Kayla
    47
    I chose Vista, because that is the operating system I have. After I installed it the pen worked. Then I recalibrated my screen, after that I had no function at all. Then I just uninstalled it hoping my pen would work.
  6. P8RSON
    5,189
    If it stopped working after you recalibrated, did you try re-installing it again?
    Failing that, do try the driver I mentioned in the link above.
  7. Kayla
    47
    It worked, my pen is fully functional! Woot! Thanks P8rson...
  8. P8RSON
    5,189
    No Problem....
    Pleased it all got sorted out for you :)
  9. docta b
    docta b Pen Pal - Newbie
    Hi everyone,
    Is there an updated WACOM driver that people are using now which is better than the one that came on our r1f's? I went to this site: http://www.wacom.com/tabletpc/driver.cfm but the driver there says its for XP tablets not for ones running Vista. I think on the European website the vista drivers are available, but im not sure which version to install..any tips? thanks
  10. scrambler
    301
    19
