Looking for Windows Tablet, 6-10hrs battery life, keyboard accessories, and built in battery in accessories acceptable. $2,000 max
Discussion in 'What Tablet PC Should I Buy?' started by dsmwookie, Jan 14, 2013.
  1. dsmwookie
    dsmwookie Pen Pal - Newbie
    21
    General Questions.
    1. What is your budget?
    $2,000 is the maximum, but this is only for a ton of add ons, battery life, raw power, and great display with exceptional build quality. If it is $2,000 and I have to buy accessories it can shove off.
    Not for that amount of money.
    Windows PC Tablet
    10 to 13-inches
    Above 13-inches
    United States
    Not a huge fan of Dell, but I m willing to give them another shot. Dell Streak was a horrendous marketing and availability nightmare with my carrier and their customer support just continued to fumble the transaction. Although they did warranty the device quite well, but they continued to give me the wrong one.
    I ve had good results with Asus and Samsung. I honestly am looking at the best build quality, features, and warranty; yes, I understand warranty is only worth its salt if the company is.
    4-5hrs+ on the tablet alone is mandatory (closer to 5 the better); I would prefer more, but if the device has a folding keyboard or protective case that has additional battery life then I am open to that. I will need a keyboard and possibly a case regardless for the tablet so adding some battery life like in the Asus Transformer is very welcome!
    Teaching, school, consumption, project production, possibly photo editing.
    Windows 8
    Office, Word, some Photoshop.
    No, something like the Surface 8's Intel 4000 graphics is plenty.
    Had not thought about it, but that would be a great bonus and make a wicked controller.
    Screen Specifics
    1080p is very preferable.
    Not for primary use.
    That would be a nice plus. I ve heard great things about Wacom. I have no experience with N-trig.
    Component Specifics
    128gb SSD is fine. Preferably it has a MicroSD and SD slot so I can add 64 gig cards to boost that. USB is good for external as well. I am setting up cloud storage to hold data for this device and a few others.
    USB, microSD, HDMI. Those should be a minimum.
    Misc
  2. dsmwookie
    21
    Do I smell funny?
