Looking for tablets similar to Galaxy Note 10.1...
Discussion in 'What Tablet PC Should I Buy?' started by Diabolicbutterfly, Jul 14, 2013.
  1. Diabolicbutterfly
    Diabolicbutterfly Pen Pal - Newbie
    General Questions.
    1. What is your budget?
    Budget is around $500
    Yep, of course
    Preference goes to android
    5 to7-inches
    7.1 to 10-inches
    10-13 inches
    Above 13-inches
    USA
    Not really
    Irrelevant
    As an interactive 'look book' in the salon, diagramming hair styles and cuts, taking notes.
    Android
    All kinds, Nothin is off limits :D
    Specifics
    Not important
    None
    Misc
    I like the note 10.1, I had one a few months ago but had to return it due to personal funds at the time. I'm looking in the market again for a tablet the same as or similar to the note 10.1, which means it needs some sort of active digitizer for input. I would consider a windows tablet as long as it isn't too much more than my budget and is very light weight.
  2. inferno7799
    inferno7799 Pen Pal - Newbie
    27
  3. darkmagistric
    1,933
    1,019
    Interesting....I didn't hear about the Excite Write yet. Can't tell if that's a Wacom pen or one of the newer N-trig pens. but it looks like it has an eraser would indicate Wacom.
    Aside from that...the only tablets that would really be comparable to the Note 10.1 price and size wise are the Lenovo Thinkpad Tablet 2 and the Dell Latitude 10. Both are 10.1 screens like the Note...but they use a 16:9 ratio instead of the Notes 16:10.
  4. Shogmaster
    Shogmaster Scribbler - Standard Member Senior Member
    3,641
    956
    That's a Wacom pen for sure. In fact, it looks exactly like their Tablet PC pen they've been using since 2005, right down to the clip.
    I'll be interested to see how much A15 does for the pen responsiveness over A9, even if it's a bit moot since even if A15 bring the pen responsiveness up to par with Clovertrail Atom, the art software available will take years to catch up to what's available in Windows...
  5. DaveOnBass
    DaveOnBass Scribbler - Standard Member
    152
    If you would like Windows, don't overlook the Surface RT now that they're dropping the price (16gb $349 or something like that). I tried out a Surface Pro for a couple days and, while it was a bit too heavy for a tablet and a bit too small for a notebook, the RT I believe is lighter weight since it doesn't need the power of the Pro. It's either 10.6 or 11" 16:9, and I have to admit I even liked the Touch cover (no moving parts on the keys) quite a bit. Of course, the Note 10.1 is still great so you could just grab another of those!
  6. seaturn
    seaturn Scribbler - Standard Member
    150
    Looks like "stylus required", kz Note 10.1 has one.
  7. Shogmaster
    3,641
    956
    Taking notes with capacitive nub - fate worse than death...
  8. DaveOnBass
    152
    My mistake, I suppose I didn't realize the Surface RT didn't have the Wacom; I just thought it ran a lighter-spec processor and a less powerful version of the OS.
