Looking for tablet PC for drawing and animating
Discussion in 'What Tablet PC Should I Buy?' started by DarthSketcher, May 15, 2017.
  1. DarthSketcher
    DarthSketcher Pen Pal - Newbie
    1. What is your budget?
    $400
    Not preferably, but yes.
    Windows tablet
    • 5 to7-inches
    • 7.1 to 10-inches
    • 10 to 13-inches
    • Above 13-inches
    10+
    USA
    Nope
    At least 4h
    Drawing, animating
    Windows!
    Photoshop, Clip Studio Paint, Animate CC, Toon Boom Harmony
    No
    Not required, but appreciated.
    Screen Specifics
    No.
    Not required
    Yes. Preferably EMR.
    Component Specifics
    8GB RAM, HDD at least 128GB. Expandable memory would be a great plus.
    USB, microUSB. HDMI and SD card not required, but appreciated.
    Misc
    Preferably a core i5, I'm not sure if the core M would perform well for the apps I want to use.
  2. surfaceproartist
    2,802
    1,696
    sonichedgehog360 likes this.
  3. DarthSketcher
    Thanks man. I didn't know about this one. I was considering the SP2 and Fujitsu T902. The SP2 because I read this 'review' goo.gl/fhu6yC
    The T902 seems solid, I'm a bit worried about the weight. But more importantly I don't wanna spend that much money since drawing/animating is just a hobby for now.
    I think I could probably discard the animation part and keep doing that on my home PC. What would be a great windows tablet for photoshop/clip studio for ~300-350 ?
  4. surfaceproartist
    2,802
    1,696
    The Cube Mix Plus is excellent for Clip Studio Paint. You could save a few bucks by skipping the keyboard.
    sunnydayz and sonichedgehog360 like this.
