Looking for linearity data for tx2x00
Discussion in 'Hewlett Packard' started by trihy, Apr 19, 2009.
  1. JJeng
    JJeng Pen Pal - Newbie
    65
    Hello, I'm looking for the linearity data for the tx2000 or tx2500 (thinking they should be the same) can someone who has an out of the box factory install (or has a really good calibration where the crosshair is always close to the tip of the pen) go into their registry and post the values that show up for
    "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\TabletPC\LinearityData"
    (hoping this will fix my calibration issues)
    Thank you
  2. chihping
    chihping Pen Pal - Newbie
    29
    Could someone with this data please post it, my touch is messed up too and I can't seem to recalibrate properly as it is too far off. Thank you!
  3. nigel
    nigel Pen Pal - Newbie
    55
    Here is my. Not sure if this help.
    REG_BINARY
    40 00 00 00 02 00 00 00
    00 00 00 00 00 00 00 00
    00 80 00 00 00 80 00 00
    00 00 00 00 02 00 02 00
    19 03 F5 04 60 04 98 07
    B3 7C F5 04 50 79 D8 08
    19 03 B8 7A 90 04 88 77
    B3 7C B8 7A F0 78 C8 76
  4. chihping
    29
    Thank you! I will be trying it as soon as i can get the wacom driver to work a bit better. Using vista 64bit ultimate and performed clean install. Got all the other drivers and SP1 to install properly, but right now using the pen doesn't disable the touch, tried w/ the hp wacom drivers. Anyone know how to fix that?
  5. chihping
    29
    Does anyone by chance know what the key is called?
  6. amuller
    amuller Pen Pal - Newbie
    Hi, I did a windows reinstall too, and lost my calibration info. So I search on the internet and found this that works for me:
    1) Created a shortcut on my desktop pointing to "tabcal.exe novalidate" (without quotes)
    2) Execute
    3) Calibrate with my fingers
    4) Save
    Hope this can help you.
  7. trihy
    trihy Scribbler - Standard Member
    171
    can someone upload linearity registry original file for tx2510?
    thanks
