looking for best stylus tablet or convertible laptop
Discussion in 'What Tablet PC Should I Buy?' started by tris, Jan 31, 2014.
  1. tris
    tris Pen Pal - Newbie
    Jan 31, 2014
    Right now, I want to replace my macbook pro 2010. I had bought Microsoft surface pro for my wife and enjoying how one note works. List of beast that I consider are Lenovo Thinkpad Yoga, Sony Vaio 15a, Fujitsu Q704 (QH77/m and Panasonic MX3. However, after reading a lot of review it seems all of candidate has some minus points. which I summaries:
    Lenovo Yoga:
    Pro: sturdy design and light
    Cons: Single Channel RAM, some reports on dead zone
    Sony Vaio 15a
    Pro: Best Performer among others, dedicate graphics, 16 GB RAM, 2880x1620 display
    Cons: louds fan, a lot of problem when upgrade to windows 8.1, weak WIFI
    Fujitsu Q704
    Pros: Great case and processor
    Cons: Processor is underclock so performance below surface pro 2
    Panasonic MX3
    Pros: Dream Machine for stylus street warriors: 1.16 Kg, 8 GB, i7 4500U, 14.5 Hours battery life with hot swap
    Cons: Hefty price 313000 Yen or $3100 :-(
    I dream if there is a monster stylus with spec like MacbookPro 15 retina but with stylus.
    1. What is your budget?
    up to $2500
    NO
    tablet pc or notebook convertible
    Above 12-inches
    Japan
    No
    >6 hours
    Note Taking and Coding
    windows and Mac no android
    One Note, MatLab and Eclipse
    PES, FIFA and FIFA Manager
    Yes
    Screen Specifics
    Full HD or better
    No
    Pen is a must, wacom or N-Trig is ok
    Component Specifics
    16GB RAM and at least 256 GB SSD
    USB 3.0 and HDMI
    Misc
    none
    none
  2. Tekn0
    Tekn0 Pen Pal - Newbie
    Jan 26, 2014
    82
    Remember the Sonys have n-trig and not Wacom. Although N-Trig is catching up I heard the pressure curve and general sensitivity is not as good as Wacom.
  3. tris
    Jan 31, 2014
    It's more catching on due date as coupon 20% for thinkpad Yoga and Fujitsu q704 ended today. I've try nTrig in Store and I think it is fill my need.
  4. Fire1Fly
    Fire1Fly Pen Pal - Newbie
    Jan 28, 2014
    Based on playing with some sony's at BB, for note taking they are to me near identical to Wacom. I believe I heard that photoshop supports ntrig pressure now but most of the artist I know are still tied to Wacom. Imo out of the bunch the sony one seems to be the best bet. To me the price is a little much but upgrading to windows 8.1 can easily be rectified with a clean install. I have had it happen on a different pc before and basically I just reformatted the drive and made a clean install of win 8.1. The only downside is that a specific 8.1 key can be hard to find. I was lucky and my university gave me some, but if the 15A is stuck on 8. You would need to "find" a 8.1 key to activate it during the install, then enter in the regular sony 8.0 key after you can reach the desktop.
Similar Threads: looking best
Forum Title Date
What Tablet PC Should I Buy? Looking for the best writing tablet. (Form Filled) Jan 27, 2013
What Tablet PC Should I Buy? Totally new to tablets, looking for the best choice. Dec 8, 2011
What Tablet PC Should I Buy? Looking at upgrade options: From Tm2 to one with *best* screen and other features (or stuff a good screen into the Tm2) Dec 16, 2010
What Tablet PC Should I Buy? Best-looking tablet? Jul 4, 2009
What Tablet PC Should I Buy? Uni student looking for the best tablet for the best bang! Jul 17, 2008
