Looking for a tablet PC for 2-D art and animation, as well as light video editing.
Discussion in 'What Tablet PC Should I Buy?' started by RizaCifra, Mar 30, 2019.
  1. RizaCifra
    RizaCifra Pen Pal - Newbie
    27
    General Questions.
    1. What is your budget?
    Preferably <$700
    Sure!
    No real preference. I've only really owned convertible notebooks so far, though.
    • 10 to 13-inches
    • Above 13-inches
    United States
    Not really, as long as it's reliable and is capable of doing what I need.
    My old laptop got me 2 hours, so honestly I think most suggestions will get me at least that, which is fine with me. Haha
    Typical web tasks and word processing, 2-D and animation, light video editing for animations.
    No real preference. I currently use Windows and Android, but I'm fine with Apple products.
    Office and art programs similar to Sai and Photoshop mostly.
    Probably won't be using it for games very much.
    If possible, but not necessary.
    Screen Specifics
    Not really.
    Yes to both (if possible).
    I require a pen with pressure sensitivity. No real preference unless there's a significant and noticeable difference to using one over the other.
    Component Specifics
    I'd like expandable memory. No requirements really.
    I'd prefer full-sized USB and SD card slots. HDMI is nice, but not required.
    Misc
    Nothing in particular that I can think of.
    I'm upgrading from my current T902, and my previous notebooks were the T5010 and Tecra M7. But my T902 is starting to show its age and is a bit cumbersome for everyday travel. I'd definitely enjoy something more portable
  2. Shogmaster
    4,154
    1,419
  3. RizaCifra
    27
    Thank you so much! I was just looking at this as well!
    Shogmaster likes this.
