Looking for a simple tablet for note-taking?
Discussion in 'What Tablet PC Should I Buy?' started by a__, Nov 26, 2012.
  1. a__
    a__ Pen Pal - Newbie
    I consider myself fairly tech-savvy, but I don't really know the tablet lingo, so forgive me if something doesn't make sense!
    1. What is your budget?
    Preferably under $200.
    Eh, rather not, but not totally against it.
    Definitely don’t want anything loaded down with media. Slate type is preferable.
    ~8.5 x 11”
    USA
    Not really. Something that would work well with Apple products, but not an iPad. It doesn't need to be specially tailored for Apple products or anything, I just need to know that it will work the way it's supposed to.
    As long as possible. Preferably something similar to the Kindle in its minimal energy consumption.
    Note-taking, some doodling. I'll be using it for school. Word processing… I’d like for it to be able to recognize my hand-writing and put it into text that’s easy to work with in MS word once it’s made it to my computer, if that makes sense.
    Mac.
    MS Office, but not necessarily directly on the tablet. Just needs to transfer over fairly seamlessly.
    Nope.
    Nope.
    Screen Specifics
    Not really.
    I would like to use it both indoors and outdoors, but I’d primarily be using it indoors.
    A pen is a must, with pressure sensitivity. N-trig is preferable, as long as I can switch to pen-only when necessary. And the pen-holders are nice as well, as I’m not good with keeping up with things, though not essential.
    Component Specifics
    As much as possible, but price is more important than memory. Expandable memory would be nice.
    A fullsized USB and/or fullsized SD slot.
    Misc
    -Wifi capabilities for syncing my notes to my laptop would be nice if it won’t drive the cost up too much.
    -Option to add a physical keyboard would definitely be a plus.
    -I'd prefer something mainstream enough that there are plenty of accessories available.
    -(I think) I’m looking for something in the league of the Boogie Board RIP or the nonexistent NoteSlate. I like the Boogie Board, but I don’t really know of any other options to compare it to and I want to see what’s out there.
  2. a__
    I might add as well that I don't want a bright, battery-draining, LCD type screen. I'd prefer something more like that of the Kindle.
  3. pakopako
    pakopako Pen Pal - Newbie
    I think only the Kindle has that kind of screen (eInk).
    A friend of mine is showing off his Adam slate -- it's a tablet made in India that uses PixelXi LCD technology that makes for a low-power, high-contrast screen. The image isn't going to be as bright as with LED/LCD, but it will be more visible on a sunny day.
    That said, whats wrong with an older generation iPad? The 1st gen 16GB models are on eBay for US$200~250. Ditto with first-gen ASUS Transformers (TF101) -- though their keyboard/battery add-on is another US$100.
    If you don't mind the old age, Motion Computing has a reliable line of Intel-powered slates like the LE1600 or M1400. About as powerful as a modern tablet, but the battery won't last as long.
  4. Synergi
    Synergi Scribbler - Standard Member
    381
    So you want a new device, 8x11 that has pen with pressure sensitivity for 200? I don't think you are going to find what you want in that price range but here goes.
    HTC Flyer, its a 7'' with N-trig and I've seen new ones selling for right around 200 on Ebay. Other then that I'm at a lost.
    You could try for an HP Slat. I believe that also uses N-trig and Ive seen a few used ones sell in the 200 to 350 range. I think those are your best two choices. The Slate is Windows and the Flyer is Android.
    The Samsung Galaxy Note 10.1 can be had for double what you want to spend but its Wacom (which I like better). Honestly, HTC flyer is your best bet for a new one or you may have to go to an older tablet but more then likely those will be used.
  5. Synergi
    381
    Forgot to add since you didn't want LCD. You might want to consider something like the ASUS Eee Note EA800, it has 13 hours of battery, has pen and is a 8" note taking tablet.,. Only place you can find those are on Ebay for under 200. It doesn't support Mac though.
