Looking for a replacement for a surface 3, that can be used for photoshop and basic notetaking
Discussion in 'What Tablet PC Should I Buy?' started by kero, Sep 28, 2016.
  1. kero
    kero Pen Pal - Newbie
    I'm looking for an replacement for my broken, 4gb ram, surface 3 that can be used for making illustrations on photoshop with minimum lag, and note taking.
    1. What is your budget?
    anywhere under 1000$
    I'd prefer not to if I don't have to
    I'm looking for a 2n1 weather it's a surface like tablet or a convertible
    12' at the very lest but I'd love to get something with 15' if I can
    The US
    I don't have any dislikes. But I'd prefer to have a 2n1 that runs wacom aes for the pressure sensitivity
    I don't mind having to run with a lower battery life if I have to but I'd prefer something similar to the surface 3's 8 hours of battery life.
    Drawing, web surfing, Light entrainment (no videogames), and note taking
    I'm fine with either windows for mac so long as it can run photoshop cc
    photoshop cc and one note(or an one note alternative)
    no
    no
    Screen Specifics
    1,920 by 1,280 pixels but larger would be nice if I could afford it
    no
    I used n-trig but I'd prefer to get something with wacom AES so that I can use it's larger range of pressure sensitivity and pen tilting in photoshop cc.
    Component Specifics
    I'm ok with a lower hardware size since I put most of my work on to a mico sd but I'd prefer 8gb but expandable memory would also be cool
    I'd Love it if I had an mico sd so I could just put all of the art and brushes from my old tablet right into it but it's find if it doesn't, USB's are a must and It'd be nice if it was usb 3.0, also HDMI would be amazing to have but it's not necessary.
    Misc
    I don't care if the 2n1 has a back light in it's keyboard or crummy speakers, since I tend to like working during the day time or in light and like to use headphones so if there's a 2n1 pc in my price range with those issues I have no problem with that.
  2. kero
    does anyone have any ideas???
  3. mistake the mizan
    mistake the mizan Pen Pal - Newbie
    Unfortuantely, you are going to find limited options at those larger sizes, especially under $1,000.
    I'll start things out--If you don't mind going towards convertible (and somewhat on the heavy side), I would bring up the Thinkpad Yoga 14/460. 14" screen, Wacom AES, HDMI out, USB 3.0. Direct from Lenovo, or there is a $899.99 version at Best Buy.
    http://www.bestbuy.com/site/lenovo-...lid-state-drive-black/4456400.p?skuId=4456400
  4. kero
    I've actually been looking at that one and I have no problem with convertibles.
  5. Bronsky
    8,125
    5,001
  6. kero
  7. darkmagistric
    2,988
    2,146
    Considering you're going from the Surface 3....I would recommend the Lenovo Mixx 700. Its Core M is substantially more powerful then the Surface 3's atom, it has a larger 12-inch screen, keyboard cover is included, Wacom AES, and its relatively cheap, its been sold for as low as $399 by the Microcenter (Core M3, & 4GB config).
    You won't find Tilt Control though....not till Wacoms Gen 13 pens coming out next year. For now you can only get tilt control on the Cintiq Companions or the Ipad Pro.
  8. schmalvaro
    schmalvaro Pen Pal - Newbie
    To clarify, the MIIX 700 uses ELAN Microelectric's implementation of Wacom's AES spec resulting in compatibility with AES pens, but not with Wacom's Feeldriver. That said, it's a really good machine and can't be beat for the price; top of the line model can usually be had for under $700.
  9. Vaga
    Vaga Scribbler - Standard Member
    100
    How's the battery life on the miix
  10. surfaceproartist
    2,930
    1,893
    Have you looked at the m3 Surface Pro 4? I think it ticks all your boxes.
