Looking for a 2 in 1 Laptop for making professional Graphic Design art
Discussion in 'What Tablet PC Should I Buy?' started by Swimmingfrogs, Nov 15, 2020.
  1. Swimmingfrogs
    Swimmingfrogs Pen Pal - Newbie
    General Questions.
    1. What is your budget?
    <$1,500
    No
    Windows tablet pc/notebook convertible
    4. What size Tablet PC would you prefer?Above 13-inches
    USA
    6. Do you have any preferences to brand
    loyalty or dislikes?
    No
    ~3-5 hrs minimum when I'm not near a socket to charge.
    Drawing (using PS) and multi tasking
    Windows.
    Illustrator, PS, InDesign. Looking to do some light 3d work eventually.
    No
    Sure.
    Screen Specifics
    4k
    2. Will you be using the tablet outdoors?
    Yes, but not often.
    Do you need to be able to see it through glare from the sun?
    No
    Either AES or EMR. I require a pen with tilt support, I've been spoiled by the Apple Pencil 2. I know I can't recreate that Apple experience, but I hope to have something similar to it. 4k+ sensitivity, tilt, and must not require batteries to charge.
    Component Specifics
    16 gb ram, 512 ssd
    Multiple 3.0 usb ports, must be able to be displayed by monitors, earphone/headphone jack.
    Misc
    Webcam for zoom calls and high sRBG AND high Adobe rbg. Both are a must. I'll also be taking this to school so it would be nice if the computer's fans doesn't make a screaming banshee noise when it's using Adobe CC.
    Looked into Microsoft Surface Pros and Dell Xps convertibles, but not sure if they are good in the long run. The c940 is one of my choices, but I'm hesitant because of lack of tilt support and jittery lines. I'm digging Acer's Concept D laptops, but they're over my budget.
  2. Marty
    3,690
    3,862
    Unfortunately, there are no Windows, 4K EMR options under $1500 (Samsung is having a massive sale on 4K OLED EMR Chromebooks though :)).
    For 4K AES, you could look at the current Lenovo Flex 5 15" (pen not included) and Yoga C930 13.9" (AES 2.0), which both come it at just under $1500 (and maybe cheaper with Black Friday coming up ;)).
    *EDIT: Looks like the Flex 5 15" might be AES 1.0 according to this post (conflicting info from Lenovo).
    JoeS likes this.
