Locked Fujitsu Lifebook T901. Need help :(
Discussion in 'The Tablet PC Life' started by schummimichi, Apr 13, 2012.
  1. schummimichi
    schummimichi Pen Pal - Newbie
    Hey Guys,
    im new on this forum. Before I start: I´m german also sorry for my bad english ;-)
    My father buyed a Fujitsu Lifebook T901 with TPM Chip.
    In my opinion he has locked the notebook/tablet.
    When I start the device it shows no Display. Only the "key-LED" is lightning.
    I can enter a pin-code with the tablet-Keys: 1-4 & ENTER.
    But my dad don´t know the pin-code.
    Can I reset this code? The fujitsu hotline cannot help me but I think this are idiots.
    Thanks for your help. :)
  2. Frank
    3,847
    116
    You won't be able to fix it yourself, only Fujitsu can but it will cost some money to remove the key, luckily, else the whole security system would be useless ;)
    Your father must have run the 'Security Panel Application' in Windows, a Fujitsu Tool which allows you to set a system password which you have to enter with the buttons you mentioned. Something like:
    Show him this picture, maybe he remembers the application and remembers what combination he selected.
    Also remember, that you can press several buttons at the same time, so like button 1 and 3 simultaneously.
    So maybe he just entered a combination like:
    1-1-1-1-Enter or
    1&2&3&4-1&2&3&4-1&2&3&4-1&2&3&4-Enter or
    1-Enter or
    1&2&3&4-Enter
  3. schummimichi
    Hi,
    thank you for your help.
    Unfortanaly your solution didn´t work. The notebook is now on the way to Fujitsu. :)
    Thank you very much.
