Lightweight laptop for drawing
Discussion in 'What Tablet PC Should I Buy?' started by Vynru, Feb 10, 2019.
  1. Vynru
    Vynru Pen Pal - Newbie
    I apologize for making yet another post on this forum, but because of some changing circumstances I need your aid yet again.
    In November I made a post on this forum, and at the time I went for a Chuwi Hi13 for just some light drawing. It's honestly been pretty good and especially cheap. But now I am planning to travel a lot more from the summer on. So instead of being away for only a couple of hours a day, I might be away from my main computer for several days or maybe months eventually. So where the Chuwi was more than enough before, I don't think it will hold up very well if I depend on it that much.
    Next to that, the microphone broke, otherwise I probably would've just settled with it, but at least this gives me an excuse haha.
    Now that my budget is higher, it'll probably be easier to find a good fit. Many advised against the Chuwi Hi13, but for drawing purposes it's been fine for me, so 1024 pen pressure levels would be enough, and I can survive with a glassy feel. Most of all it's very important that the laptop is very light, preferably not heavier than 1.1/1.2 kg (2.4/2.6 pounds), the lighter the better. But on the other hand I like having a keyboard that doesn't just stick on like with Surface Pro-like models, so I can have it on my lap easily (these two are by far the most important things to me). More power is always nice, but it doesn't need to be huge.
    One thing that annoys me is having the screen heavier than the keyboard so I have to press down to keep it in place. So a better weight distribution would be a pro.
    General Questions.
    1. What is your budget?
    600-800, but I can go up to 1000 or so. But whatever I end up choosing, I'll probably wait for a sale since I don't need the laptop until summer anyway.
    No, only new.
    Detachable is fine, but it needs to run Windows 10 and have a keyboard it can lean on (so it stays on my lap).
    • 5 to7-inches
    • 7.1 to 10-inches
    • ----> 10 to 13-inches <----- (preferably above 11/12 inches actually)
    • Above 13-inches -----> maybe, 14 is still great
    Netherlands
    I'm a fan of Lenovo. I've been looking at the Yoga 730 13 inch with the lowest specs for this, but I'm not sure if it's a good one since I don't hear about it much.
    EDIT: Actually nvm, the 730 seems like a bad idea. I've seen reviews about the screen flickering. I still like Lenovo, though.
    The more the better. At least 6 hours.
    Drawing most of the time, as well as some writing. I won't push it with video editing, but if that ends up being possible, I'd definitely be happy.
    Windows 10
    Clip Studio Paint, Discord, Open Office, stuff like that.
    Only if it's possible, but it's absolutely not a requirement. Probably unwise since I overworked my arms and shouldn't hurt them by gaming.
    No.
    Screen Specifics
    HD and above. I'm a fan of nice displays, but it's not the most important thing. As long as it doesn't have a horrible color inaccuracy, I'm good with it.
    I probably will.
    A pen with pen pressure sensitivity of 1024 and above, above 4k if possible but not absolutely required. No preference other than that, since I apparently didn't have a major problem going from my old Wacom Cintiq 13 to the Chuwi pen.
    Component Specifics
    I don't need a lot of memory. I tend to throw all of my stuff on Dropbox.
    At least one full-sized USB. The rest doesn't matter a lot.
    Misc
    It would be really cool if the pen could go inside the laptop/be attached to it with a magnet like on the Chuwi, but that's definitely not required.
    Maybe average/good sound quality but I can't think of anything else.
