Light-weight TabletPC with large screen, durability and stability
Discussion in 'What Tablet PC Should I Buy?' started by cleft, Jun 23, 2018.
  1. cleft
    313
    55
    I am looking for a replacement to my current setup: a 15" workstation (for coding) and a Surface Pro 3 (for reading/note-taking/drawing). However the combined weight is straining on my shoulder, so I am looking for a more portable solution (<2kg).
    I am deciding between MS Surface Book 2 (with dGPU), Lenovo ThinkPad 370, HP Elite X2 1012 G2, Acer Switch 7 Black edition, but also open to other options.
    In short, it seems that a Surface Book would fit my needs, but the instability I had with my current SP3 (hang at booting, occasional waking-up from sleep), make me hestitate to go for another tablet from Microsoft.
    Thanks alot
    Answers to the survey questions:
    1. What is your budget?
    <US$2500
    Yes, if the device has proven durability (e.g. Macbook Pro or business-grade series such as ThinkPad, Elitebook, Latitude etc)
    Windows TabletPC (either detachable or foldable/convertible is fine)
    or 1 laptop + 1 penable Tablet (iPad Pro or Windows tablet).
    Please see answer to question 8 and 10
    • 5 to7-inches
    • 7.1 to 10-inches
    • 10 to 13-inches
    • Above 13-inches
    Preferrably from 13 to 15.6 inches, but 12" is acceptable if there is no larger-screen device that satisfies other requirements
    Vietnam/Singapore
    No
    5-6h+
    I will use the device extensively for coding, reading, and making hand-writing note. Though not very often, I also like to draw when I take a break.
    No
    - Coding with memory-hungry software (~300MB at start-up)
    - Reading: Chrome with 20+ tabs; PDF Reader with 5-10 documents opened
    - Note-taking with OneNote
    - Drawing with ClipStudio Paint
    - Word-processing + making presentation with MS Office and LyX/LaTeX
    No
    No
    Screen Specifics
    1080p or above
    Rarely
    Yes, and with pressure sensitivity. I prefer N-Trig/Wacom AES, unless the new Wacom EMR is parallax-free
    Component Specifics
    Minimum 8GB RAM, 200GB storage
    No hard requirements
    Misc
    Discrete nVidia GPU with 2GB+, or ThunderBolt3 port (for eGPU)
    Durability. I sometimes do some heavy lifting, which is equivalent to gaming, that stresses the CPU (and GPU if available) for ~30 minutes continuously. It will make excessive heating in that duration, and certainly affects longevity of the internal parts. As for detachable tablets, I am also worry about the effect of heat to the bond between digitizer and screen panel.
    Stability. While I like the Surface Book line, I have seen many complaints about the base getting disconnected intermittenly, crashing the programs that are using the dGPU, or worse, the system. I also faced other instability issues with the current SP3 (eg hang at booting), which disrupted the continuity in my workflow (and my focus) more than often. Therefore I absolutely want to avoid that as much as possible.
  2. WillAdams
    887
    365
    I use LyX/LaTeX on my Samsung Galaxy Book 12 and it works well --- a similar machine more in line w/ your specifications would be the HP Zbook X2 (which I'd consider getting if Microsoft would get this whole select text in Microsoft Edge, and allow stylus to be used in legacy applications thing fixed)
    Starlight5 likes this.
  3. Starlight5
    Starlight5 So what if I'm crazy? The best people are.
    666
    213
    @cleft consider newer Thinkpads - Thinkpad X1 Yoga 3rd gen with HDR display and X380 Yoga. These are durable business-class convertibles with eGPU support; Thinkpad (Yoga) 370 you mentioned is somewhat outdated because of dual core CPU, while 2018 models come with quad-cores.
    cleft and WillAdams like this.
  4. cleft
    313
    55
    Yes, I'm also LyX'ing (if it is the right word :D) on my SP3 just fine. Still the lack of dGPU/TB3 port is a deal breaker, unless I pair the SP3/Galaxy Book 12 with another laptop for my workflow.
    Zbook X2 looks really promising. Hope that I can find some used one in where I live, otherwise importing from abroad would blow off my budget with import tax included :(
    Thanks @Starlight5 ! I totally forgot the X1 Yoga. Will certainly look into it.
Similar Threads - Light weight TabletPC
  1. Vynru
    103
