  1. thundercracker
    thundercracker Pen Pal - Newbie
    49
    Got the sleeve today. It's odd in how useless it is, offering about a quarter inch of "protection" and nothing else. Can't recommend.
    ATIVQ likes this.
  2. highlander747
    highlander747 Pen Pal - Newbie
    I am going to buy the 15.6 1080p version with i5
    does it support a pen and if yes will it work with : Bamboo Smart for select tablets and 2-in-1 convertible?
    I am going to use it as a note taking when I am studying.
  3. surfaceproartist
    2,930
    1,893
    Yes but I recommend the new Bamboo Ink pen instead.
  4. ATIVQ
    ATIVQ V⅁O⅄ Senior Member
    1,041
    587
    A 15.6", 4.4. lbs device for note-taking? I hope you work out. And personally, I think it's criminal to get a 15.6" device with only 1080p display.
  5. highlander747
    the cost of the smart is 43 usd ( I converted the price from my currency) and the ink one is 99 usd do you think its worth the investment ? if yes why
  6. surfaceproartist
    2,930
    1,893
    4,096 pressure levels, lower IAF and a soft touch triangular barrel that is more comfortable to grip. Only you can say if that's worth the extra $50+ to you.
  7. torq
    torq Pen Pal - Newbie
    If feel like I'm loosing my mind but weren't there more options available to buy on Lenovo's site just last night? I don't seem to be able to find the 720 with the 4k screen...
  8. ATIVQ
    1,041
    587
    Stock shifts pretty often on Lenovo's website. With their constant shortages and lengthy delivery times it's better to buy their computers somewhere else.
  9. Pogibaer
    Pogibaer Pen Pal - Newbie
    Dear torq,
    you are not loosing your mind. The reason might be problems with the 4k Screen as described in this post: https://forums.lenovo.com/t5/Lenovo-Yoga-Series-Notebooks/Yoga-720-Display-Issue/td-p/3711026 . Lenovo ist working on a solution. It Looks like the problem is hardware based.
    Greetings,
    Pogi
  10. surfaceproartist
    2,930
    1,893
    I have to break down and buy a compatible Type C hub ASAP. Recommendations?
    Apologies if the topic has already been discussed in this thread but search's limitations have let me down here. Hub is too short. C is in every post and Type is somewhere in between.
