  1. southdunes
    southdunes Scribbler - Standard Member
    257
    149
    @ATIVQ, were you able to settle on a docking solution? Interested to hear the result -
  2. ATIVQ
    ATIVQ V⅁O⅄ Senior Member
    1,022
    577
    More impressions...
    Dongle:
    • Went with the Juiced USB-C BizHub. It offers the most interfaces: HDMI, SD, MicroSD, 3x USB 3.0, verified 1000Mbit Ethernet speeds, and USB-PD which I haven't tested but I assume isn't supported on the 720-15. My external USB 3.0 harddrive actually reads and writes slightly faster when it's connected through the dongle than directly to the 720-15. Weird.
    Battery life:
    • Don't get this device if you have to work away from a power outlet, or a desk tor that matter.
    • If you're on battery power, switch to "power saver"... You won't notice the CPU throttling unless you're doing something you shouldn't be doing on battery power...
    • The battery is rated for 72Wh, but mine is already reporting 70Wh full charge capacity.
    • Battery life is very sensitive to CPU usage. Thankfully, it appears that the CPU is very efficient when it comes to decoding video, so you could maybe make it through 9 hours of watching video on long trips, on 0% brightness. I've only tested it for one hour and it drained 11% of the battery.
    • Putting the brightness at 30% would probably knock that down to about 6.5 hours. Tested for one hour, drained 15%.
    • Office use (Wi-Fi, web-browsing, word processing) would cut it to 4 hours.
    • There's a "conservation mode" in the Lenovo Settings app that limits battery charge to 60%, so less stress is placed on the battery compared to being 100% charged. It's a nice feature for people who keep our devices plugged in all the time, like me.
  3. MrRedPanda
    MrRedPanda Pen Pal - Newbie
    Having the Laptop now somedays with only 1080p and like it so far.
    I don't see why you don't get a good response with your pen. After I adjusted it in the preinstalled WACOM PEN software and tried to adjust the slider a bit, I got a pretty good pressure curve in comparison to EMR it doesn't lack anything at all.
  4. ATIVQ
    1,022
    577
    Gotta congratulate Lenovo on their above-and-beyond customer service. I had a tiny bit of trouble registering my product for warranty, so I contacted support. Turns out their website was undergoing maintenance. Without me even asking, they added another month and a half to my warranty and tossed me a Lenovo Store coupon ($10-$100 off depending on the total). Incredible!
    testdrive7 and Starlight5 like this.
  5. southdunes
    257
    149
    I'mStillLearning likes this.
  6. BigDragon
    BigDragon Pen Pal - Newbie
    21
    21
    I got the 1TB Yoga 720 off Lenovo's site for $1399 recently. It arrived a few days ago. I can share the promo link and code via PM (it shouldn't be posted publicly).
    So far the machine seems nice! I had to tweak the UEFI settings and disable all the Dolby and audio crap (seriously -- they're just crappy laptop speakers, not some surround powerhouse). I haven't had time to draw on it yet other than a few quick strokes to confirm it works. There was some sort of uneven coating on my screen so wiping it down was important to stop the stylus from squeaking. Removing the Lenovo Active Pen nib and re-inserting it was also critical (it arrives stock with the nib shoved in too deeply). Stylus seemed very responsive and quick to activate to me. I don't have a decision on pressure response yet, but I will say the positioning accuracy is better than my Wacom EMR Fujitsu T902.
  7. thundercracker
    thundercracker Pen Pal - Newbie
    49
    I can't believe you can get a 1TB ssd these days for that much. Is there any disadvantage to having a 1tb over a 512gb, as far as speed and reliability?
  8. BigDragon
    21
    21
    I've had a 1TB SSD in my desktop for 3 years now. No problems. It's a SATA 3 model so not as fast as the Yoga 720's PCIe SSD.
    The extra space may improve performance and extend useful life. Filling up an SSD is bad since it degrades the wear-leveling technology's ability to perform its job. Having ample extra space gives a larger pool of memory for wear-leveling to utilize. SSDs from reputable brands are reliable these days, so I don't think there's any concern about failure likelihood being higher or lower for different sizes of SSDs in the Yoga 720 (I believe they use Samsung SSDs).
    I bought the 1TB because I know I'll probably put 600 to 700 GBs worth of data on this thing.
    thundercracker likes this.
  9. I'mStillLearning
    I'mStillLearning Pen Pal - Newbie
    Has anyone found a protective case and a screen protector (clear and matte) for it?
  10. ATIVQ
    1,022
    577
    People here will undoubtedly recommend Photodon. Personally I don't use one. For better pen friction I'd get a soft nib (although the current soft Smart 2-in-1 nibs aren't rubbery enough) and to protect from keyboard grime I'd cover the display with a microfiber cloth whenever I shut it.
