  1. thundercracker
    thundercracker Pen Pal - Newbie
    49
    Hmm sorry to hear that. That's what we get for listening to Best Buy customer reviews I guess.
  2. surfaceproartist
    2,930
    1,893
    It's ok. This misadventure gives me the opportunity to run this machine through its paces, write up a review and return it to Best Buy with a clear conscience!
    ATIVQ, southdunes, alaskajoel and 2 others like this.
  3. alaskajoel
    alaskajoel Scribbler - Standard Member
    156
    67
    Looking forward to it!!
    southdunes likes this.
  4. ATIVQ
    ATIVQ V⅁O⅄ Senior Member
    1,026
    580
    Review requests: • How large is the gap between the pen tip and cursor • How severe is the line wobble • What's the fan noise at light load (watching a video, browsing the internet) and heavy load (encoding video etc) • Does the non-dGPU version have 4 PCIe lanes for Thunderbolt 3?
    Then I just need to know what are the 4K display specs and it's off to the races.
  5. surfaceproartist
    2,930
    1,893
    No problem except for the last question. Where would I find the answer?
  6. cutterline
    cutterline Scribbler - Standard Member
    246
    80
    HWInfo like this one for the GTX1050 version
  7. surfaceproartist
    2,930
    1,893
    HWInfo reports the same values here. So what does 2x link width mean?
    cutterline and ATIVQ like this.
  8. kvoram
    880
    784
    That's sad, so Lenovo crippled that device. :(
    The x2 link width means that the Thunderbolt 3 port is only connected with two lanes of PCI Express Gen 3 lanes, giving you only half the bandwidth for data or eGPU use instead of the full 40Gb/s.
    Displayport data is unaffected since that does not use the PCIe lanes, so it can still run two 4k@60Hz screens etc.
    But if you transfer data or connect an eGPU (if it is even supported), you can essentially only use it like a Thunderbolt 2 port.
    Some explanatory discussion with regard to Dell doing the same thing: https://egpu.io/forums/pc-setup/xps-15-9550-not-able-to-reach-40gbps-over-tb3/
    Can you please check if the properties of the Thunderbolt Controller say whether eGPU is supported?
  9. surfaceproartist
    2,930
    1,893
    I'm not seeing a Thunderbolt controller in Device Manager. Where should I be looking?
  10. kvoram
    880
    784
    I am not 100% sure, but I think you have to go through the Thunderbolt software instead of device manager.
    IIRC, the Thunderbolt controller only appears in device manager when something is connected to it.
