Lenovo Yoga 520/Flex 5 for 2D animation?
Discussion in 'What Tablet PC Should I Buy?' started by Dellaclearing, Jul 15, 2017.
  1. Dellaclearing
    Dellaclearing Pen Pal - Newbie
    Hello, I'd really appreciate some help and advice with buying a new tablet from all you experts please!!
    Up until recently I owned a Core i5, 128 SSD, 4gb Ram Surface Pro 3 until it died on me completely out of the blue without any warning! Just went to sleep and refused to ever wake up! Out of warranty Microsoft wanted nearly £500 to replace, and although I loved it, that was too expensive for an old device.
    I'm an Animator/Illustrator, my main applications are Adobe Flash/Animate cc, Illustrator, Photoshop, After Effects and Premiere. I also use Construct 2 to design mobile games and have been thinking of moving into Unity recently. All of these programs ran fine on my SP3.
    1. What is your budget?
    £7-800
    No, would rather buy new, preferably with long warranty!
    Windows nootebook.
    • 12 to 14-inches
    England, UK
    Avoiding Surface line after my SP3 died unexpectedly!
    6-8 hours, but the longer the better.
    Drawing, illustrating, animation, web surfing, entertainment
    Windows only.
    10. What software and tasks do you intend to run?
    Adobe Animate cc, Illustrator, Photoshop, After Effects, Premiere, Scirra Construct 2.
    Maybe I'll start learning Cinema 4D and Unity soon.
    11. Do you intend on playing Games?
    No games. I develop simple 2D games for mobile, and may begin designing 2.5D games in Unity soon. But I am no gamer, never play high end games on PC.
    I may occasionally hook it up to a TV screen via HDMI but that would be all.
    Screen Specifics
    1080p or higher
    Very unlikely.
    Absolutely MUST have a pen. Preferably Wacom, I've tested EMR on a Lenovo Miix 510, the experience was very good. I've never tested an AES panel before but have read positive feedback on this forum.
    Component Specifics
    256gb SSD, 8gb RAM. Expandable would be a nice option for the future.
    Full size USB port/s, MicroSD or full size SD card slot would be okay as I can use an adapter. Either micro or full size HDMI port. At least 1 x USB C would be nice too.
    Unless someone has a better suggestion, I'm thinking about a Lenovo Yoga 520, (known as the Flex 5 in the US)
    http://www3.lenovo.com/gb/en/laptops/yoga/500-series/Yoga-520-14/p/88YG5000829
    ... It's currently £750 for an i5-7200U Kabylake, 8gb Ram, 256 SSD, 14" 1080p screen. I also like that it is openable so hopefully more repairable/upgradable than the SP3 was. It gets pretty good reviews in terms of battery and performance and has all the ports I need. Only drawback, but certainly no deal breaker, is that it only comes in an unattractive grey colour!
    It's compatible with Lenovo Active Pen (not included, I'll need to buy this separately), I believe this is a Wacom EAS system which I've never tried before but seems to have positive feedback on this forum. I recently tried and liked the pen on the Lenovo Miix 510 tablet (Wacom EMR) but I don't now how similar this experience is to AES.
    There is also an NVIDIA GeForce GT 940MX 2GB GDDR5 graphics card, I don't know if this will help performance with the software I use though?
    I'm not a gamer and have never had graphics cards in my computers and always managed to run Flash, Photoshop, even Blender before. I may move into Cinema 4D and Unity for 2.5D game development in the future though as these are becoming popular in my field. Intel 620 graphics are pretty good these days though so maybe I don't really need a graphics card? This isn't really an area I know anything about I'm afraid.
    There is also an i3-7100U version with Intel 620 too. It's only £629 but has a 1TB 5400 HDD, 2 cell battery instead of 3 but still has 8gb RAM, so maybe I could get away with the i3 and just upgrade to an SSD? This one is available in black which is a big bonus too!!
    Thanks in advance for any help and advice!!
  2. Mooni_nooni
    Mooni_nooni Pen Pal - Newbie
    77
    I was planning on buying the flex 5 too the 14" model . but my local PC store owner (the best around) told me its poor in quality, very plasticy but has all the specs on a budget,the main trade off that the screen display is a bit dim and its plastic, so you gotta take of it.
  3. surfaceproartist
    2,936
    1,834
    I only played with the Flex 5 briefly at a local Best Buy. I didn't think it felt cheap at all. I would get the best device you can afford with a minimum 8GB RAM, an i5 processor and discrete graphics. That will handle most anything you throw at it. Any less will tend to choke on animation rendering.
    Mooni_nooni likes this.
  4. Mooni_nooni
    77
    Idk, but store owners usually reject the idea of the flex for some reason.
    There could another reason and they won't mention it. It made me skeptical but I still had it in my mind.
    I just think in general if Dellaclearing wants it they you gotta see it with your eyes first and exam in it well.
  5. cocoua
    cocoua Pen Pal - Newbie
    hi are you sure Miix 510 uses ERM? because I'm reading all over other sites that is using AES, this is the only place I found it as is using ERM.
    thanks
  6. Shiratori
    Shiratori Pen Pal - Newbie
    35
    We have 3 Miix 510 tablets in this household and I can confirm that it's AES.
  7. cocoua
    OK!
    Thanks!
    And do you know if Adobe Animate brush tool works good or it have some problems like surface pro3,4,5?
    In the n-tring surfaces, brush starts deawing a second after you push, so a straight line appears at the begining of each stroke. This is a well known problem in Adobe comunity, just wondering if wacom aes has it too, as both system are active ES
