LE1700 lost pressure sensitivity
Discussion in 'Motion Computing' started by virtualibi, Sep 13, 2013.
  1. virtualibi
    virtualibi Pen Pal - Newbie
    23
    hello, suddenly on my le1700 stylus stopped drawing in a "sensitive" way on photoshop and sai. i tried same on deviant muro, same, no pressure sensitivity.
    BUT on onenote 2010 it works fine.
    please, help :( i do not know what to do, i tried few times to reinstall pen driver which i found on lenovo site, but it didn't work.
  2. thatcomicsguy
    3,291
    2,346
    The LE1700 is a Motion Computing product, not Lenovo.
    I don't know what the source of the pressure problem might be, but it definitely sounds like you've installed some funky drivers which may not play well with your machine.
  3. stoneseeker
    3,666
    1,116
    Try using the free version of CCleaner to do multiple registry cleans after uninstalling the current Wacom drivers. Then, find the default Motion LE1700 wacom drivers from off their site and re-install.
    It's near the bottom of the list. Make sure you select the operating system you are using on the top of the list... windows 7, or vista or xp. Motion Computing - LE1700 Tablet PC Support
  4. virtualibi
    23
    i tried, it didn't work... :(
  5. virtualibi
    23
    what about if i reinstall windows on tablet pc, will the pressure sensitivity start to work again? thanks..
  6. thatcomicsguy
    3,291
    2,346
    It depends on what the problem is.
    If it's not a hardware issue, then a nuclear mouse-hunt (HD wipe and total OS re-install) ought to work.
  7. jnjroach
    4,021
    1,406
    Moving to Motion Forum
  8. virtualibi
    23
    i reainstalled windows, still the same problem.
    i tried to do what you wrote here again, still nothing changed.
    is there anything else i can do?:(
  9. balistic
    balistic wacom jock
    244
    167
    It could be a problem with the stylus. The pressure sensing hardware inside eventually wears out ... maybe you can borrow another stylus to test with
  10. virtualibi
    23
    hmmm..
    the pressure sensitivity works in One Note and Sticky Notes program, but not on photoshop etc. i think if the problem was in stylus it wouldn't be able to show pressure sensitivity anywhere at all. am i wrong?
