LE1700 built-in 3G slot not working
Discussion in 'Motion Computing' started by cheRRymonk, Jun 29, 2013.
  1. cheRRymonk
    cheRRymonk Pen Pal - Newbie
    It's first time I'm trying to get 3G broadband work. After I insert a sim card nothing is popping up. I installed Novatel Mobilink and Novatel Wireless Broadband driver but it doesn't seem to work. But I noticed a 3G Connection appeared in Network Connections but it says "Device missing". My OS is XP and BIOS version A18. There's WWAN option in BIOS but it's unavailable "No device". I bought this PC in US but I'm leaving in Russia, is this the "key"?
  2. Steve S
    8,107
    3,627
    <<...There's WWAN option in BIOS but it's unavailable "No device"...>>
    cheRRy: Based on the information in your post, it doesn't sound like your LE1700 has a broadband 3G radio installed. Open the Device Manager and see if there is a broadband device listed. If not, then you have your answer. If so, the next thing I would look at are the Novatel drivers. They may not actually be compatible...
    Good luck...
  3. cheRRymonk
    Oh, I thought a broadband module is a built-in option so far I have a sim slot in my LE1700... So I have to buy a WWAN card and insert to PCMCIA slot to be able to use 3G Connection?
  4. Steve S
    8,107
    3,627
    <<...I thought a broadband module is a built-in option...>>
    ...It's not uncommon to find ports and slots for optional extras pre-installed. I've owned several tablets that have had sim card or other ports installed, but didn't have the actual feature.
    I don't have an LE1700, but I assume that you can purchase the appropriate broadband radio card and install it...
