LE1600 vs LE1700. What should i choose?
Discussion in 'Motion Computing' started by dragoni1, Jul 31, 2011.
  1. dragoni1
    dragoni1 Dragoni1
    I know the two are very old models.
    But i want to get one as my sub tablet.
    I don't want too much functions, too high speed. Just good tablet function.
    And, i just want to check how much different the two is.
    1. If 'speed/screen resolution/pen input' is similar, I will choose cheap one.
    2. If LE1600 is considerably slow or screen is too dark or much much worse wholly, I will choose expensive one.
    Is there any big difference on the two?
    What's your advice?
    thanks a lot.
  2. jack33
    jack33 Pen Pal - Newbie
    24
    You have pm
  3. darkmagistric
    3,092
    2,254
    I don't have either, but from what I've gathered, the 1700 is more powerful, but the Outdoor display model on the 1600 is much better then the 1700's outdoor display option.
