Latitude XT touchpad unresponsive at times
Discussion in 'Dell' started by davidd31415, Nov 26, 2009.
  1. davidd31415
    davidd31415 Pen Pal - Newbie
    27
    I'm wondering if anyone else with a Latitude XT suffers from problems with the touchpad.
    It will be working fine and then suddenly the pointer will not move when I slide my finger across it. Usually the second or third try results in the pointer moving. It seems as if the computer is "froze" or the touchpad "stalls."
    Using the eraser-stick or tablet input works fine- no problems like this whatsoever. I've noticed it in both Vista and 7. I like this computer for the most part but the touchpad issue is one of the most annoying problems I have ever run into while using a laptop.
    David
