Kensington lock doesn't work in tm2?
Discussion in 'HP TouchSmart TM2 (Wacom)' started by codys, Feb 12, 2011.
  1. codys
    codys Pen Pal - Newbie
    22
    Hi everyone, I've been trying to get my kensington lock to lock my tm2 to my desk. I know the lock works fin, and I know how to use it. I can't get it to lock once I put it in my laptop though. Has anyone had a similar problem?
  2. Zimoich
    Zimoich Pen Pal - Newbie
    89
    Have used one third part kensignton lock and one genuine kensington lock with my tm2.
    No problems at all.
    As this is such a simple mechanism, I can only see two options.
    -Your lock doesn´t work properly or the hole on the tm2 is full of dirt/defective built.
    -You don´t know how to use it. (No offence meant)
  3. codys
    22
    I know for sure that the lock is not defective. I used it on my past laptop and it worked fine (HP too). Do you think it's possible that it is a problem with my laptop? I just tried it with my friend's lock and it doesn't work either. I put it into the lock hole and I can't press in the lock, regardless of where I position it
  4. Zimoich
    89
    Try taking a small screwdriver, or something other and have a feel inside the kensington hole. There should be empty space all around after the 2 mm thick casing.
    Seem to that me, that you have to RMA or have a talk with HP.
  5. codys
    22
    Nevermind, it seems that I got the lock to work properly. Thank you for your help!
