It finally happened
Discussion in 'What Tablet PC Should I Buy?' started by poetdante, Feb 20, 2008.
  1. poetdante
    1,042
    My 3yr old R15 broke. The screen is about to loose it's casing. Just around midterms. I need a new tablet. Since no 14.1" screens are available, I'll go with 12.1 if it's a slate. What slate tablets besides Motion are available?
    1. What is your budget? I would like to keep it under $2000 but that may be hard with a slate. I only know of Fujitsu and Motion that have slates.
    Slates
    12.1" or more
    U.S.
    Toshiba or some Japanese company.
    about 3.
    OneNote, Office, Firefox.
    Windows
    Office, OneNote, IE. FireFox, nothing serious.
    Nope.
    Screen Specifics
    Is there even a choice anymore? I'd go with widescreen.
    Doesn't matter.
    Would be nice, but not necessary.
    Active
    Wacom
    Component Specifics
    I need an 80gb hard drive or more. Is it possible with a slate? RAM wise I guess 1GB or more
    I rarely used mine so far so no.
    Would be nice, but I mangaged to live on just one battery so far.
    Misc
    Something durable. It can be tough being a student
  2. SimsHsia
    3,293
    Hey poetdante, welcome back -- long time no see! :D
    The only 14.1" Tablet PC that is currently available is the Gateway C-141 series, however that's a convertible...on to the slates:
    And, yes, generally slate Tablet PCs are more expensive than convertible Tablet PCs, so it will be difficult. In addition, most (current) slates have at least a 40GB hard drive, but it is possible to go beyond 80GB. These are the slates that I can think of so far:
    - Motion Computing LE1600 (discontinued ~ available from eBay, or other online stores that have them in stock)
    - Motion Computing LE1700 (12.1" SXGA+) ~ $1,799+ direct from Motion Computing (from Dell.com: $1,509+ with a Intel Core Solo -- no Core Duos)
    - Fujitsu Stylistic ST5111 (10.4" XGA) or ST5112 (12.1" XGA) ~ $1,999+
    - TabletKiosk Sahara i440D (12.1" XGA, has active and passive digitizers) ~ $2,295+
    - Electrovaya Scribbler 4000 (12.1" WXGA) ~ $2049+
    On a related note (although you state you want Windows):
    - Axiotron ModBook (modded Apple MacBook turned slate with Mac OSX) ~ $2,279+
    None of the slates above have a modular bay, but I do know that the LE1600/LE1700 has a battery slice that can be attached on to the unit where there is a recessed area. Most of the other Tablet PCs have high-capacity battery options which will add to the overall width of the system itself.
  3. poetdante
    1,042
    Thanks. It's good to be back. I didn't know about the gateway. See, I want a slate because the size to thickness ratio just doesn't work for me with 12.1 tablets. I don't know about Gateway, die hard Japanese company guy and all, but I'll look into it. The $2300 Motion doesn't look afordable and I don't know much about the company quality wise. I'm a student so I need the thing to last. Though a thin slate would be nice to use instead of a convertible. Thanks for helping me out.
  4. Sassafras
    Sassafras Scribbler - Standard Member
    218
    I personally love my ST5020D, but I got tired of going between my Laptop and my slate, so I purchased a T4220. I, too, was worried about the thickness after going from a slate, but to tell you the truth, it really isn't so bad. I propped my slate up with a book so I could write at an angle while taking notes. I do the same with my convertible, and I can honestly say, the thickness hasn't bothered me as I thought it would.
    Now my slate just sits in my case :(, it is still a great computer and I would like to find a use for it especially since I just upgraded the hard drive. As far as slates go, I really like the Fujitsu because in portrait mode you get a wrist rest out of the deal and excellent quality. Other than that I would recommend the motion. Both companies produce quality slates and I personally like to buy for quality.
    When going from my slate to the T4220, I did not feel like I lost screen real estate whatsever. If I were you, I may want to reconsider a 12.1 inch convertible. You may find it not to be as you expect.
    -Sass
  5. KingArthur10
    KingArthur10 Pen Pal - Newbie
    83
    I have the Gateway C-140XL and can say I'm impressed for the price. I've been wary of Gateway, but the price coupled with the free 3yr warranty they threw in for me was just too good to pass up. It's a bigger laptop, but I love the screen realestate for class notes. I'm a math major and typing just doesn't work for notes, but with handwriting, it's great. Also, the Gateway came with Microsoft OneNote which is a dream for organizing my notes.
  6. poetdante
    1,042
    Ditto on the Math major here. My dad has an IBM at work. I'll take a look at it and see how it works out. Still, fantasies of walking around with a futuristic slate like in StarTrek would be nice. Maybe I'll go with a fujitsu or toshiba.
