Is it possible to work with excel in a tablet?
Discussion in 'What Tablet PC Should I Buy?' started by rbata, Jun 9, 2008.
  1. rbata
    rbata Pen Pal - Newbie
    Hi.
    I was looking for a notebook a few weeks ago, something with great video card, huge screen, lots of HD, something that would substitute my desktop PC.
    I ended up with the problems of portability and battery duration.
    Most of the the time I spend in front of a computer is working/developing in Excel or surfing on the internet, doing researches or just for fun.
    I´m not into games anymore and even if I want to play something I can go to my desktop PC which isn´t that bad yet for the games I´m used to play.
    So I´m changing for something smaller, lighter, something that can take me away from my chair and desk.
    With all that in mind, I need your help to choose one tablet PC for me.
    General Questions.
    1. What is your budget?
    Don´t know, something around $2.000 is enough?
    Convertible
    13~15"
    USA or Brazil.
    No.
    At least 4h.
    Most of the time to surf the web, to run some spreadsheets in Excel and a little bit of Photoshop.
    Windows XP or Vista.
    70% - Internet explorer, MS Office (Excel, Power Point and Word), Outlook Express.
    10% - Watching videos from the internet
    10% - Photoshop
    10% - Autocad, Solidworks and Catia. (just for visualization purposes, not to design on the tablet, no need for dedicated video card)
    No.
    Screen Specifics
    If possible wide.
    SXGA - 1400x1050 ~ Small text and graphic icons which require good vision but the gain is a much larger screen.
    or
    WXGA - 1280x768 ~ Wider viewing angle of XGA but ideal for viewing Spreadsheets and other programs that require desktop space.
    Indoor.
    Active.
    5. Do you require Wacom, Finepoint, or N-Trig Technology?
    Wacon? I really don´t know, never tested any of them.
    Component Specifics
    The HD don´t need more than 60~80Gb.
    2 or 4Gb of RAM.
    Does they usually have an optical drive? I guess I need one, unless I can install things trough a network using my desktop optical drive?
    No.
    Misc
    Good processor, something better than my desktop processor (Athlon 3200 64bits), something like a Core 2 Duo 1.6 ~ 2.0 to run some spreadsheets fast.
    Fast wifi and if possible bluetooth.
    That fingerprint thing would be nice but I can live without it.
    VGA or HDMI out to connect to my LCD display.
  2. DRTigerlilly
    7,086
    410
    271
    There are two tablets that fit your size requirements the Asus R1F,13.3'', but it suffers from battery drain and static issues, and the Gateway c142x/xl, 14''.
    The c142x has intel x3100 graphics and the c142xl had ati dedicated graphics. Its has a built in optical drive and all the other specifications you mentioned.
    Re excel you can't write into the cells normally you can use the tip to write into formula area but it seems like a waste of time, and you can ink into the cells, using the review button, but there is no character recognition. It doesn't seem very efficient.
  3. rbata
    Thank you very much.
    I´ll take a look at these models you suggested.
    And thanks for the info about the use of excel on a tablet.
    I´ll go to a store and try any HP tablet before buying because they are much easier to find here in Brazil.
