Is it Possible to Replace a Normal Screen on an X200T with a Superbright Screen?
Discussion in 'Lenovo (IBM)' started by hitman, Apr 26, 2012.
  1. hitman
    hitman Scribbler - Standard Member
    172
    Really like my new (old) Lenovo X200T but wish the screen was brighter. Have wondered about replacing it with a superbright outdoor screen but is it possible to fit one if the laptop was set up to run a normal screen - does anyone know?
    Cheers
  2. hitman
    172
    Is it possible?
    Has anyone done this before?
    Where's the best place to source the screen?
    Cheers :)
  3. AndreR
    AndreR Scribbler - Standard Member
    146
    Probably. I have seen people replaced the x200 display (cheap ugly TN-panel) with an AFFS and it worked.
    However, the background light is more powerfull in the outdoor display which means that you would probably need to change the inverter, which powers the background light. You would also have to make sure that the displays fits and has the same display port as the motherboard.
  4. starburst
    starburst Pen Pal - Newbie
    Hi,
    Does the LED model have an inverter?
