iPhone X
Discussion in 'Apple/iOS' started by Kumabjorn, Sep 12, 2017.
  1. convergent
    390
    175
    71
    I will not buy one. I think they made a big mistake removing TouchID and adding FaceID. They should have done both for a transition period, and I'm sure Jony Ive probably had a play in it not being both... his designs have never been in favor of usability over look. Also, the notch in the screen looks silly to me... I'd rather have the black bar across the whole screen. What value is there to expand the screen by that amount and then black out 60% of it?
    DRTigerlilly and JoeS like this.
  2. JoeS
    3,824
    1,842
    They really messed up that part imo. I can't find the mockup right now, but someone showed your proposal, but with the time and status icons in white in the black space next to the notch. That would have looked perfect. The current solution looks dreadful.
    Ed Hardy likes this.
  3. Kumabjorn
    3,740
    1,776
    Uhm, please explain the FaceID fiasco then. Didn't exactly come off as bugs been worked out.
    But I do get what you are saying, and to me, though I could be wrong, it illustrates the difference between a CEO that is a visionary and one that is a Master of Logistics.
    siddhartth and Starlight5 like this.
  4. Azzart
    1,743
    1,166
    If you mean the fail when he tried to unlock the iPhone with face recognition, that's because iOS when you turn on the phone wants you to insert the pin in any case before accessing in any other way.
    Which I frankly find a nonsense. -.-
  5. Shizaru
    Shizaru Scribbler - Standard Member
    453
    301
    You may not see it that way when your other half uses your face while you're sleeping so they can access your phone? They may not be too impressed when they discover how much time you spend on your passion for all things tech.
    siddhartth, Azzart and DRTigerlilly like this.
  6. convergent
    390
    175
    71
    Except the message displayed when it failed wasn't the reboot pin message, it was the failed message.
  7. Azzart
    1,743
    1,166
    It said: "enter passcode - your passcode is required to enable face id".
    Which is exactly what you get when you turn on an iphone before being able to use touch id.
  8. Kumabjorn
    3,740
    1,776
    An iPhone want a face ID in order to enter a touch ID?
  9. ryanstuart
    ryanstuart Pen Pal - Newbie
    No, I am not gone a buy this new iPhone, Its too expensive.
    I would prefer to go with other low range phones from Samsung.
  10. JoeS
    3,824
    1,842
    I found one of those user-enhanced UI versions. The one on the left is what Apple went with. The one on the right is what a sane internet user came up with. I vastly prefer the non-Apple version.
