iPad Stuck on Headphones: Weird But Easy Fix
Discussion in 'Apple/iOS' started by Ed Hardy, Jul 7, 2013.
  1. Ed Hardy
    Ed Hardy Editor, TabletPCReview Staff Member
    2,755
    242
    When I woke up this morning, my iPad would only play sound through the headphones, even though there were no headphones inserted and I almost never use the headphones jack, as I have a Bluetooth pair from Plantronics I like a lot.
    This wasn't a case of the tablet being on mute and me not realizing it -- when I adjusted the volume, the pop-up windows was clearly label "headphones".
    Plugging in a regular set of headphones and unplugging them did nothing. The sound worked, but the device stayed stuck on headphones even when I pulled out the plug. I got the same result with my Bluetooth headphones.
    I also did a shut down and restart, as well as a reboot. No luck,
    I did some research and tried a couple of things. The first was "Reset All Settings". Still no luck.
    Then I tried what I thought was a dumb suggestion: I got out a paperclip and tried cleaning out the headset port. I thought this was silly because I take good care of my iPad and I know the port isn't jammed with lint or anything else.
    Still, much to my surpise (and happiness) I now have sound through the speakers again. I didn't find anything in the port to clean out, but it still did the trick.
    So if this happens to you, try what I did.
  2. Ahmelt
    Ahmelt Pen Pal - Newbie
    I just registered to say: it Worked for me Thank you! Same thing happened to me this morning with my mom's iPad and I tried what you did , Thanks a lot
    Ed Hardy likes this.
  3. alex2020
    alex2020 Pen Pal - Newbie
    I had the same problem but they made me change my speakers. Cost me a lot too!!! :(
  4. Cat Lover
    Cat Lover Pen Pal - Newbie
    I'm nervous 'bout the paper clip thing cuz i dont wanna mess it up but I'll try it.....
  5. Cat Lover
    :(-Didn't work :(:(:(
  6. Ed Hardy
    2,755
    242
    Sorry! I was using an iPad 3 when I wrote that. What model are you having problems with?
  7. Olivier86049
    Olivier86049 Pen Pal - Newbie
  8. Debbiebeth
    Debbiebeth Pen Pal - Newbie
    I tried the paper clip and then I tried a Q Tip with rubbing alcohol. It worked. Thanks so much for the tip, saved me much grief and possibly some dough too.
  9. Lalagirl
    Lalagirl Pen Pal - Newbie
    My iPad mini 4 speakers say I have headphones in them out of the blue and I cannot figure out to fix them.
