iPad Already Has Workaround for Meltdown Processor Bug, Spectre Fix Coming Soon
Discussion in 'Apple/iOS' started by Ed Hardy, Jan 5, 2018.
  1. Ed Hardy
    Ed Hardy FORMER Editor, TabletPCReview Staff Member
    2,755
    259
    Almost every processor made for years (or even decades) has a pair of security vulnerabilities which have been dubbed Meltdown and Spectre. This, unfortunately, includes the chips in iPad and iPhone. However, the announcement of these bugs didn’t catch Apple napping, and there is already a workaround in iOS 11.2 to deal with the first of these, and the company promises to introduce a new version of the Safari web browser in the near future to deal with the second.
    The details of Meltdown and Spectre are quite abstruse: they exploit the way processors function, allowing malicious code to gain access to protected memory. The important takeaway is that Apple can’t immediately fix the basic security flaws, as they are baked into the silicon of devices’ processors. The security fixes being introduced are intended to block hackers from taking advantage of them. To employ a metaphor, the patch in iOS 11.2 is like a board nailed over a hole in a wall; the hole is still there, even if the wind isn’t blowing through it.
    Apple isn’t the only company affected. Every Intel processor made for the last 20 years has issues with both Meltdown and Spectre, for example. AMD’s exposure is less, but it still has to fix Spectre problems.
    Apple’s Official Statement
    More details on Apple’s plans are in a statement released by the company, which also gives more complete descriptios of these processor vulnerabilities:
    About speculative execution vulnerabilities in ARM-based and Intel CPUs
    Security researchers have recently uncovered security issues known by two names, Meltdown and Spectre. These issues apply to all modern processors and affect nearly all computing devices and operating systems. All Mac systems and iOS devices are affected, but there are no known exploits impacting customers at this time. Since exploiting many of these issues requires a malicious app to be loaded on your Mac or iOS device, we recommend downloading software only from trusted sources such as the App Store. Apple has already released mitigations in iOS 11.2, macOS 10.13.2, and tvOS 11.2 to help defend against Meltdown. Apple Watch is not affected by Meltdown. In the coming days we plan to release mitigations in Safari to help defend against Spectre. We continue to develop and test further mitigations for these issues and will release them in upcoming updates of iOS, macOS, tvOS, and watchOS.
    Background
    The Meltdown and Spectre issues take advantage of a modern CPU performance feature called speculative execution. Speculative execution improves speed by operating on multiple instructions at once—possibly in a different order than when they entered the CPU. To increase performance, the CPU predicts which path of a branch is most likely to be taken, and will speculatively continue execution down that path even before the branch is completed. If the prediction was wrong, this speculative execution is rolled back in a way that is intended to be invisible to software.
    The Meltdown and Spectre exploitation techniques abuse speculative execution to access privileged memory—including that of the kernel—from a less-privileged user process such as a malicious app running on a device.
    Meltdown
    Meltdown is a name given to an exploitation technique known as CVE-2017-5754 or "rogue data cache load." The Meltdown technique can enable a user process to read kernel memory. Our analysis suggests that it has the most potential to be exploited. Apple released mitigations for Meltdown in iOS 11.2, macOS 10.13.2, and tvOS 11.2. watchOS did not require mitigation. Our testing with public benchmarks has shown that the changes in the December 2017 updates resulted in no measurable reduction in the performance of macOS and iOS as measured by the GeekBench 4 benchmark, or in common Web browsing benchmarks such as Speedometer, JetStream, and ARES-6.
    Spectre
    Spectre is a name covering two different exploitation techniques known as CVE-2017-5753 or "bounds check bypass," and CVE-2017-5715 or "branch target injection." These techniques potentially make items in kernel memory available to user processes by taking advantage of a delay in the time it may take the CPU to check the validity of a memory access call.
    Analysis of these techniques revealed that while they are extremely difficult to exploit, even by an app running locally on a Mac or iOS device, they can be potentially exploited in JavaScript running in a web browser. Apple will release an update for Safari on macOS and iOS in the coming days to mitigate these exploit techniques. Our current testing indicates that the upcoming Safari mitigations will have no measurable impact on the Speedometer and ARES-6 tests and an impact of less than 2.5% on the JetStream benchmark. We continue to develop and test further mitigations within the operating system for the Spectre techniques, and will release them in upcoming updates of iOS, macOS, tvOS, and watchOS.
  2. doobiedoobiedum
    717
    247
    I've been trying to explain to an AMD using colleague that he probably is at risk too but he just won't believe me.
  3. Ed Hardy
    2,755
    259
    As promised, Apple has released iOS 11.2.2 to fix the Spectre security flaw that’s made the headlines in recent weeks.
    According to Apple’s official security page:
    iOS 11.2.2 includes security improvements to Safari and WebKit to mitigate the effects of Spectre​
    This update doesn’t seem to include any other changes. As mentioned earlier, a fix for the related Meltdown bug was already included in iOS 11.2.
    More about iOS 11.2.2
    iOS 11.2.2 is available for all recent models of iPad and iPhone, as well as iPod. To install it, go to Settings > General > Software Update, or connect the iOS device to a laptop or desktop running iTunes.
